Question about Garden
New onan 18 hp engine installed in a 318 jd no spark repaced cap,
My new engine bg43 has no spark this engine is brand new I replaced the cap and coil from old engine thinking this may be the problem still no spark any suggestions ?I have checked the points where do i go from here?
5 Suggested Answers
  • 850 Answers
SOURCE: Is there a way to test the ignition condensor on
not worthtesting just replace it if its suspect as they are only cheap to buy & easy to fit
Posted on Jul 25, 2009
  • 69 Answers
SOURCE: I have an onan 18 hp twin cylinder (early 90's
Hunting & surging usually is the carb. main fuel jet is dirty, restricted fuel passage, or the governor. Try running some Seafoam carb cleaner through the gas tank first and see if it helps, and don't use ethanol-blended fuel. It absorbs moisture.
Posted on Sep 09, 2009
nova2nv
  • 197 Answers
SOURCE: john deere 318 wiring diagram I replaced an bg 316
Purple wire goes to the solenoid on starter.If you installed starter with single wire post all you have to do is mount a solenoid to the frame just in front of starter,existing batt/starter cable goes to one solenoid post,purchase a short red cable and install on other solenoid post and run it to the starter,plug purple wire into new solenoid and the way you go.
Posted on Nov 16, 2009
Testimonial: "This was great advise bought a solenoid and away i go thx"
Biggdex35
  • 333 Answers
SOURCE: I have a JD 1020.
Doe's it run? Is it in time? If it runs and is in time. did you set the dwell? You have to have a dwell meter to set it. Unless you can guess. Adjust the screw on the points while it is running and see if it runs better. After you set it you have to set timming again. Or vise versa?
Posted on Oct 02, 2010
I have a 1999 Tahoe 8 cylinder I put in a new coil a whole new distributor distributor cap still it will not start
Pull the coil wire off the distributor cap. Put a ***** driver in it and place it close to any metal on the engine. crank over the engine. If you have spark, replace the pick up coil/ignition module in the distributor. If you have no spark. Check for power and ground at the coil plug with engine on. If it is there , replace the crank sensor.
Apr 18, 2016 | Cars & Trucks
I have power to my coil but none coming out on my 84 351 Windsor brand new distributor coil is good module came on new distributor I need help ?
Since the coil is getting power you need to get a spark tester or pull a cord of one spark plug and lay it on the engine and have some crank the engine. You should see and hear a spark. If not check fuses and check the ignition module - that is the device that tells the the coil to send a spark. You could also remove the wire from the coil to the dist cap and look for a spark.
Jan 04, 2016 | Cars & Trucks
Rebuilt 318. Everything new. 125# comp all cyl. except 6 and 7. No change when I pull wires. What's wrong?
318 Small Block Build - How To - Hot Rod Magazine
www.hotrod.com > Hot Rod > Engine > News
They are rarely considered for a rebuild because performance pistons are hard ... 3/14 1 A key problem with 318s is that the pistons are typically well below the ...
Weird engine problem Dodge 318.. ' The H.A.M.B. - The Jalopy Journal
www.jalopyjournal.com > ... >
Apr 13, 2012 - 30 posts - ‎18 authors My van is a 67 a108 van with a 318 in it. ... Yea timing or a cam problem, Check your TDC and make sure you didnt strip something out. ..... old guy was the original owner) that the engine was rebuilt about 15,000 miles ago. old dodge 360 trouble
Jan 15, 2012
Problems with my 318
Jul 31, 2009
More results from www.jalopyjournal.com
Oct 28, 2015 | Cars & Trucks
No spark at plugs
Do you mean you get spark from coil high tension wire to dizzy cap? If so, the only thing left is the cap and rotor and wires and the engine must have a good ground.
Apr 07, 2015 | Hyundai Motor 1993 Excel
Why number 1 and 5 don't get any spark from the coil 4.2 engine
check that you have the HT leads in correctly. Check inside the distributor cap for a crack around these points. The ECM will not be at fault as the lead you would have moved was the coil wire to the cap so look in that area for the fault.
Aug 02, 2014 | 2006 Ford E-150 Chateau
Masport 635 starts, revs up once, and dies. Will start again a few pulls later. Carb diaphragm has been replaced with no change. Could it be ignition? Thanks.
follow this steps and fix it. God bless you
Carburetor
If the lawn mower engine stops after a few seconds, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the lawn mower for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
Carburetor Kit
If the engine stops after a few seconds it may not be getting enough fuel. The engine needs air, fuel and spark to maintain operation. The carburetor has two inputs, fuel from the gas tank and air through the air filter. The carburetor is designed to mix the air and fuel in a consistent ratio so that the engine can run continuously. If the carburetor is not getting enough air or fuel, or if the fuel is blocked inside the carburetor the engine stops after a few seconds. Rebuild the carburetor with this carburetor kit.
Gas Cap
If the lawn mower engine stops after a few seconds and then stops running, the gas cap might be defective. All gas caps have a small vent to allow air back into the tank when the engine is running - otherwise as gas is drawn from the tank it would create a vacuum. The vent can be difficult to see and there are many different types of vent. If loosening the gas cap a little allows the engine to stay running, replace the gas cap. It's sometimes possible to clean the vent, but on most newer engines the vent cannot be cleaned, it should be replaced.
Gas Cap with Gauge
If the lawn mower engine stops after a few seconds and then stops running, the gas cap with gauge might be defective. All gas caps have a small vent to allow air back into the tank when the engine is running - otherwise as gas is drawn from the tank it would create a vacuum. The vent can be difficult to see and there are many different types of vent. If loosening the gas cap a little allows the engine to stay running, replace the gas cap. It's sometimes possible to clean the vent, but on most newer engines the vent cannot be cleaned, it has to be replaced.
Old or Bad Gasoline
If the lawn mower stops after a few seconds, the carburetor might be clogged or have old or bad fuel in the float bowl. If old fuel was left in the lawn mower for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This old or bad fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old or bad fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
Spark Plug
If the lawn mower engine stops after a few seconds the spark plug might be defective. All small engines have an ignition coil. The coil is the device that provides spark for the spark plug(s). If the coil is bad there won't be spark to the plug(s). The coil is essentially a small, induction generator. It is mounted next to the flywheel. The flywheel has one or more strong, embedded magnets. As the flywheel spins, the magnet(s) zip past the induction coil, this action of a magnet passing past a coil induces a voltage. Depending on the design of the coil and the strength of the magnets, a stronger or weaker spark can be created and delivered to the spark plug(s). Each time the flywheel spins around a spark is generated. The best way to test a spark plug is to use a spark plug tester. The spark plug should have a strong, visible spark between the electrodes when the engine is cranking. If it doesn't, replace it.
Nov 13, 2013 | Garden
Hi i have a Suzuki sj 413 and its got su carb and brand new coil but there's no spark at all and its been rewired by the haynes diagram but still no sparks it turn on the starter motor but nothing
old post. , its not stock, and you failed to state the year.?
sure
no spark these old cars have a 100% dedicated Distrib.
there is no EFI , early years.
the is a coil of that has no spark then the Dizzy VR and inside ignitor is bad.
if the spark is dead at 4 spark plugs or very weak and ok at the coil that means the timing on the CAM or the Dizzy or both is way off.
caused by rotor sparking between cap tower positions.
http://www.fixkick.com/
Jan 29, 2013 | 1994 Suzuki Samurai
No spark from coil
change your coil.
Aug 24, 2012 | 1988 GMC Jimmy
Brand new lawnmower has no spark
if you have no spark remove the upper engine cover and remove the small wire from the coil if still no spark the coil is bad
Jul 06, 2012 | Garden
Garden Logo
188 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
