Question about Frigidaire Heating & Cooling
Is the FRA124HT2 compatible with a 110 outlet?
  • 8,197 Answers
If your unit has a 115v plug like on page 2 of the manual it will plug in and work off of the 110 outlet. If it has one of the 230v plugs on it it needs to be plugged into a 220 outlet. If you do not have the manual you can download it on link below. To tell what plug you have you need to look at the prongs on the plug.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020213A0495en.pdf
Good Luck and please rate 4 thumbs for the free answer. If you have any questions please ask befor you rate.
Posted on May 01, 2010
I plugged my max 110 V Oliso iron into our house's only 220 V outlet. Smoke is being emitted and it is unusable (The iron, not iron). Can someone please tell me how to fix it?
are you saying that the iron works with 110 volts and you plugged it in a 220 volts outlet??? if so then the voltage is to high for the iron (luckily it didn't get burnt) but all you need to do is plug it into a 110 volt outlet
Jun 23, 2015 | Oliso TG-1000 Iron
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
I have brought my wok over from the UK but i have lost the electric lead firstly where can i buy one from and secondly will it be compatable with my appliance
Firstly is the WOK 220 Volt or 110 volt which is north American because if not 110 it will not work without serious house rewiring to provide you with a 220 volt outlet and then if you find a cord it will need to have the correct end for the 220 outlet you have wired in or you will have to have a compatible outlet to your cord.
Sep 21, 2014 | Rival Kitchen Appliances - Others
How can I wire a 110 outlet to a 220 outlet?
If the bed is a 220 volt, you can only use a 220 volt outlet.
If the bed is 110/220 you should check the web for specs and wireing.
May 31, 2014 | Health & Beauty
Why incessant beeping?
Good Afternoon Friend,
I understand that your Frigidaire air conditioner, model# FRA124HT2, begins with a constant beeping, and changes the modes itself, about every 30 minutes. I also see that it ends up on a different setting each time it does this. I suggest resetting your air conditioning, by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. Bring power back to it and turn it on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRA124HT2 12000 BTU...
How can i convert our 220 volts wall outlet to 110 volts for a microwave oven.
Find the breaker for it (a double for 220) and substitue a single breaker (for 110). This will leave one wire unused from the breaker box to the outlet. You'll have to change the outlet of course to accommodate a normal 110 plug. You can also skip the breaker part and just change the outlet and cap off 1 of the hot wires. Just make sure to kill the power and be safe!
Mar 11, 2010 | GE JVM1650 1000 Watts Microwave Oven
Dryer will not start door is closed
Carefully check your 220 outlet. You can check a 220 buy a volt meter. Make sure your volt meter is set over 220 range and put the red lead into the slot and black lead into the L shape. It could be you are not getting 220 power out of your outlet. We all know on a 220 outlet both legs have 110 on each side. A dryer takes 110 for the motor, and takes 110 for elements.
Dec 03, 2009 | Estate TEDX640JQ Electric Dryer
Everything works but no heat just replaced the pigtail because it was not compatible with new outlet worked before we moved
id check the power u maybe getting 110 instead of 220 breacker maybe half tripped
Oct 22, 2009 | Dryers
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Heating & Cooling Logo
229 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
