Question about Kenmore 62602 Electric Dryer
Dryer is BROKEN
The dryer just stopped working. I have reset the fuse box and still not working. The barrel doesn't spin, I've also unplugged it and tried again but it's not working at all. What could be the problem. Does a dryer have a fuse that need to be replaced inside of it?
KENMORE DRYER
Model 970-c80042-00
Serial XD03906442
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryerDryer is BROKEN - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 03, 2010
Tip
If your dryer works but no heat
whirlpool,kenmore,roper,kitchenaid,inglis,if your dryer works but no heat most of the time it is a blown fuse,or bad heating coil,cause of a blown fuse can be power surge,clogged wall vent,clogged dryer lint vent box,unplug,remove back cover,look to your right and you will see the heater box,look on the left side near the top and you will see a small fuse,this is your heater box fuse,if not the fuse,the heating coil is near the bottom,1 screw on each side,remove and look for broken wire,if you have a meter,you can check the fuse and heater coil-mike
on Feb 11, 2010 | Dryers
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
My fisher & paykel model ad39 dryer has stopped working
Always unplug the appliance before working on it.
I would suggest checking the circuit breaker in the breaker box for your apartment, to see if it has tripped. You have probably already done this, but try to reset (open all the way and then close) the circuit breaker. Plug the power cord in again and try to operate the dryer.
If it trips the circuit breaker again, there is a short circuit or a ground, and you should unplug the machine and diagnose the problem. 240 volts AC, when shorted or grounded can start fires or kill people.
Many Dryers are equipped with a "non-resettable thermal fuse". When the air being blown through the dryer gets too hot, this thing melts and opens up the entire power circuit.The dyer doesn't do anything, as if it had no power.
This non-resettable thermal fuse can usually be purchased from the manufacturer or a good appliance supply store, and comes in a kit which also includes a new thermostat, to replace the one that probably failed and overheated the machine to start with.
Get a friend who is an Electrician to help you if you are at all unsure of replacing parts in your power circuit. Be sure to unplug the machine / use a VOM to check it dead before you touch anything electrical. BE SAFE. 240 Volts AC is not just playing around.
Oct 06, 2012 | Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
I have a kenmore dryer everything works but when i hit start button it doesnt go
Check the Thermal Fuse with a multimeter for continuity, but MAKE SURE THE DRYER IS UNPLUGGED FIRST. If your dryer hose is clogged the dryer will overheat and blow this fuse. If it is the fuse, make sure you clean out your lint trap and dryer hose after replacing the fuse. If the fuse is not the culprit check to see if the motor belt that spins the drum is broken.
Feb 03, 2011 | Kenmore Dryers
The barrel won't spin. the heat is still working, but the barrel won't spin. i may have overloaded the dryer (five pairs of jeans and three hooded sweatshirts) there was a loud bang noise and the barrel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 29, 2010 | Dryers
Heat doesn't work ..dryer spins but no heat is produced
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 01, 2009 | Dryers
Whirlpool Dryer, Heats up, but will not spin.
Thermal fuse , is the small white plastic piece on the blower box . That , keeps the dryer from running . Thermal cut-off , is the small thermostat on the burner (element) box , which would keep the dryer from heating .
Jul 31, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 62602 Electric Dryer Logo
165 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
