Question about Kenmore 75085 Air Conditioner
Air conditioner runs all the time - Kenmore 75085 Air Conditioner
HOW DO I FIX AN AIR CONDITIONER DISPLAYING E6?
Hi this link is a13 page error code manual for air conditioners, Hope this helps....
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
Apr 03, 2016 | Heating & Cooling
Dehumidifier mode use Air Conditioner
Yes, normal dehumidifier operation.
Jul 18, 2015 | Heating & Cooling
My whirlpool window air conditioner' compressor
Sounds like a bit of refrigerant leaked out and it is freezing up or at least running too cold...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 14, 2011 | Whirlpool Heating & Cooling
Compressor runs for short time then kicks off and blows warm air
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | GE Profile ASM10AA Air Conditioner
The unit runs for a short time then shuts off.
Usually when that happens the unit is low on charge...
heatman101
Sep 26, 2010 | Heating & Cooling
Sometimes it runs fine and sometimes it overloads my generator
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The compressor is not starting right every time....the problem is probably the start capacitor for the compressor...
There are many things that can cause your air conditioner not to cool…
heatman101
Sep 09, 2010 | Dometic Rooftop RV Air Conditioner
Why the central air conditioner unit run out of freon at all times
it has a leak....freon system is a closed system, and should never run out of freon...leaks are sometimes hard to find.
Jan 25, 2010 | Whirlwind FH-778 Air Conditioner
Furnace and Air conditioner run at the same time
Odds are u did just that or wrong thermostat,If u don't have a digrahm get one from Library.
Oct 02, 2009 | Dometic Rooftop RV Air Conditioner
E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Jul 26, 2008 | Danby DAC8003D Air Conditioner
Air Conditioner stop running
first thing ck the t-stat then breakers otherwise i need more info dan
Jul 23, 2008 | Weather King 10PJA2501AH Air Conditioner
Kenmore 75085 Air Conditioner Logo
193 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
