Looking to replace my standard speakers on
Looking to replace my standard speakers on pioneer xj110 system. amp is 275w and speakers are 100w a piece. what would you recomend, and maximum watts without damaging amp. Thanks Rich.
  • 616 Answers
Use the same wattage, make sure the impedance is the same
Posted on May 01, 2010
Want to use my current speakers with a new surround sound system. Current system is 5.1 channels, rated at 100w per channel @ 8. Ohms. New System is rated 145watts, 5.2 channels at 6 Ohms. Will b ok?
Hi Ronald.
8 Ohm speakers will work just fine as replacements for the
6 ohm speakers. When fitting speakers you need to consider
The power handling capability. The impedance and the frequencies
involved. Power handling is expressed in wattage ie 100W.
Unfortunately this can be expressed in rms, max or peak music. The rms value (root mean square) is the only really relevant figure as this is the continuose handling power at 1 KHz. The impedance
is the resistance that the amp sees but is not a dc resistance and
varies with frequency. The lower the impedance the more power
will be drawn from the amp. In the event of a short circuit across
the speaker the amp will try to deliver infinite power into an infinitly
small load in an infinitesimal amount of time and will self destruct.
Using an 8 Ohm speaker draws less power than a 6 Ohm speaker.
Connecting speakers in parallel; results in the impedance beingreduced. For example two 8 Ohm speakers in parallel will result
in a 4 Ohm impedance load but in series will be 16 Ohms.
Incidentally the the .1 (5.1) is the sub woofer which only has
to handle the bass frequencies, a small percentage of the
amplifiers overall frequency response..
Connect your speakers and then power up the amp last
after double checking there are no shorts on the speaker
cables.
All the very best from Vintie.
Jan 07, 2017 | Audio Players & Recorders
Pioneer XC-IS22CD 100w CD/Tape/Radio Stereo what is the size of this
dear sir this is it all
Dimensions (W x H x D) 215 x 372 x 274 mm (S-IS22 speakers)
Dimensions (W x H x D) 160 x 300 x 237 mm (M-IS22 Amplifier)
Dimensions (W x H x D) 204 x 300 x 237 mm (XC-IS22CD head unit)
just tell me if i was helpfull
Aug 12, 2011 | Pioneer IS-22CD CD Shelf System
I've just been given a Wharfedale S-990 Amplifier, Tuner CD etc tower - but without any speakers. Output is 2x50W - but the impedence isn't specified. I'm just looking for advice on what...
Anything in the neighborhood of 8-ohms will usually fly safely with standard audio amplifiers. At only 50w x 2 you want efficient speakers. Watch the volume as this amp may clip if driven too hard. THAT will kill any speaker.
This owner had Valdus 200's and was happy. But just about any quality speaker in the 100w range should work out.
http://www.avforums.com/forums/hi-fi-systems-separates/368695-wharfedale-s990-any-good.html
Jun 22, 2011 | Audio Players & Recorders
Can you run a 1200w pioneer sub and 2x9x9 inch car speakers to a 600w pioneer 4 channell amp??
depends on what the RMS is for the subs because although the subs are 1200 watts, there is a minumim standard you have to follow. If you don't atleast run the lowest wattage thru them, then you will most definately damage the speakers....you should also be aware of the fact that your "600w Pioneer-4 channel amp doesn't even push a true 600 watts... Your best bet is to upgrade ur amp, or add an additional amp to your set-up. And you really need to pay close att to over or under running your power to your stereo system because you'll burn out ur altenator rather quickly. Use proper wattage , and you should also look into getting a power-cell which lessens the chances of destroying your altenator and helps to ensure that your stereo system sounds to its full potential.....
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
Hello,I'm trying to conect 4 speakers(Bose 161,4-8ohms,50w each) and 2 speakers (JBL cf100(3way speakers),8ohms,100w each) to rceiver Pioneer VSX-455, I want to conect all of them at the same time.please I...
Well if you look on the back it plainly says speakers should be between 8-16 ohms.
It has facilities for 2 pairs of fronts (A and B) which could be run concurrently if they met the >8-ohm spec.
http://www.use.com/PIONEER_767cb5bb4ea6f30a06fc?p=7#photo=9
http://www.use.com/showorig.pl?set=767cb5bb4ea6f30a06fc&p=6
The JBL's would work best as primary front speakers.
http://www.retrevo.com/support/JBL-CF100-Speakers-manual/id/597bh151/t/2/
If you wired the Bose in series with each other, they'd work as one surround speaker 'pair' electrically, maybe even sonically if you arrange them across the sides and/or rear. I'd experiment.
http://products.bose.com/pdf/customer_service/owners/og_161.pdf
You'll need a separate amp for any center or sub speakers.
Feb 03, 2011 | Pioneer Audio Players & Recorders
My sub keeps popping when working?
Hi there
If this happens on high levels, popping from your subs generally relates to the cone being over exerted and reaching the physical limits of the cone travel, or the amp is approaching its limits resulting in clipping and producing square wave peaks on transients This sort of problem can generally be tuned out of a system by careful adjustment of EQ and drive levels. If the system has been working fine to date, and this is a new problem that has just started, then you may have a failing sub.
regards robotek
Apr 20, 2010 | Ohm PIONEER 12" DUAL VOICE COIL 1000W 4...
Connent Bose speakers to Sharper Image SA250 System
Probably. HTIB's are all-in-one for a reason. They typically are not recommended (or explicitly recommended against) mixing and matching with other products or damage can result. Glaring (but not mandatory) evidence of that would be non-standard connections that don't use bare wire ends to connect the speakers to the amps.
I can't find documentation on the SA250. How are you connecting the 501's to it?
Feb 23, 2010 | Sharper Image SA250 CD Shelf System
How to check high power amps by using bulb series technic
You can use CFL (Compact Flourescent Lamps)
100W CFL is cooler and brighter than the standard 100w bulb. Therefore, for the same performance, a 60W CFL is equivalent to the
100W bulb.
Sep 22, 2009 | Audio Players & Recorders
No Audio when disconnect from external amp and hook to speakers
In a radio like your Pioneer and all similar units there are always a pre-amp circuit that feeds a power amp circuit,In some players there are more than one pre-amp circiuts. It is possible and highly probable that the power amp circuit in your Pioneer is shorted, so you still get some audio output , but very little. I believe this is your problem and I suggest that you bring it to a repair shop for an estimate or replace the unit. Good luck and please rate this answer, Thanks.
Apr 12, 2009 | Pioneer Car Audio & Video
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
