Question about HP Photosmart C5180 All-In-One InkJet Printer
How do you enlarge a copy from small to fit to page
  • 4,041 Answers
Hi there
This will do what you want pluse lots more beleave me.
The best program to put on your Pc is what I use and it is Free you, it is called PagePluse SE, you should try it you can do all sort of things with it but there no scan on it, just scan your photos to the your pc with another program witch has scan on it and put them in the SE program and you can do any size you wont and after adding text to it or backgrounds you can send it to the printer and print, an other program I use for scanning from the printer to the PC is called PainShop Pro 7 witch is a old program there newer ones out now but I am happy just using the old one it does the trick.
The Free version is Called PagePluse SE you not need the version 9.
Ok here the link to download the PagePluse SE program and it not a free trial it a free, there is one you can Buy but this is all you need download the free one it just as good.
Click Link = http://www.freeserifsoftware.com/software/pageplus/index.asp
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
3 Suggested Answers
SOURCE: enlarge copy
I went to a store that has enlarging equipment.
z8131
Posted on Jan 15, 2009
SOURCE: How to enlarge a picture that is scanned or
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Posted on Aug 07, 2010
Epson SX405
Just set is copy as is. or one to one. Standard auto fit will always enlarge any image smaller than a full page.
Jul 16, 2014 | Office Equipment & Supplies
How do you enlarge copies on the hp 8500 printer
From The HP 8500 Manual
TIP:You can also use Fit to Page to enlarge a small photo to fit within the
printable area of a full-size page. In order to do this without changing the
proportions of the original or cropping the edges, the device might leave an uneven
amount of white space around the edges of the paper.
Oct 01, 2012 | HEWLETT-PACKARD 8500 Wireless All-In-One...
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
Enlargements
Well one way, is to open it up with Picture manager and select "fit to page"
Jun 08, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Printing an enlarged version of a scanned photo
The best way is to use software like Corel PhotoPaint and RESAMPLE the pix to the sze you want. YOu typically will get better resolution.
You could also try selecting the "Fit To Page" setting of the printer window before you tell it to print.
Sep 14, 2009 | HP Photosmart C6280 Printer
MFC-6490CW, photocopy of 11x17 document prints 8 1/2 x 11 full scale image on 11x17 sheet. The image is centered on the 8 1/2 dimension, and located at one end of the 17 dimension. The rest of the 11x17...
First make sure you are not using "fit to page" as this feature does not work for legal size documents. To fix this problem we need to check several things. First, Press Copy, Load your document, press 1 for number of copies, press the up/down arrow until you get to "paper size" then choose legal (for 11x17). Press OK
It is also possible that your machine is set to reduce/enlarge size to less/more than 100%. If the first solution did not work start over, press copy, load document, enter 1 for number of copies, press up/down arrow to choose "enlarge/reduce" then use right/left arrows to choose 100% (again, do not choose 'fit to page') press OK. Once you have done this, you can set these as default if you like. Press Copy, press up/down arrow to choose new setting, press OK, press 1 to choose YES, press stop/exit.
Apr 18, 2009 | Brother Office Equipment & Supplies
My office has a Canon color imagerunner C3220. I want to use it to enlarge some images for a seasonal decorating contest. How do I break an image into pieces so that I can enlarge it into multiple 11x17...
I can help. In order to do this, you press the "copy ratio" then you select "multi page enlarge" from there, you can either select the number of pages you want to use (meaning the machine will calculate the percentage by which it enlarges) or you can select the ratio you want to use ie how big you want it to be (the machine will calculate the amount of pages to fit that ratio)
I hope this helps.
Dec 05, 2008 | Canon imageRUNNER C3200 Copier
Reducing/enlarging on Canon MP 160
The only option I see that comes close to this is the "fit to page" option described on page 35 in the manual. Apparently, it detects the size of the original and enlarges it to fit on the paper size selected. Otherwise, I see no options for enlarging or reducing while copying.
May 13, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
49 people viewed this question
Ben Johnson
