Question about Makita 10" Dual Slide Compound Miter Saw with Light LS1013F
My guard gets stuck when i cut a piece of wood,it dosent retract
    Brigadier General:
  • 4,088 Answers
The pivot is probably full of pitch or other debris. Clean with turpentine if you work with pine or other resinous woods.
Posted on Jun 22, 2010
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
Coleman bayside 1997 pop up camper, had to remove some motor part related to cranking up. won't stay up unless motor part is put back in. help? female with trouble and wanting to camp this weekend
Sounds like the motor also holds up the top.
can you try to use something loke a broom stick thick piece of wood to hold up the canopy top till you get a chance to get a new motor.
You would prop up the top with a piece of wood right in the same area as the framing.
Tie a piece of string or bungee cord to hold the stick in place,to ensure the top dosent come down on you.
You might need to cut the stick to leanth as well as using more than one piece of wood.
Gool luck,Gary
Sep 21, 2011 | Coleman Water Sport
Any guard blade for a saw miter
Yes, Did you buy it new? It has two heavy plastic seen through plate that are attached to each other. This safety shield is gravity fed. That mean as one pull down the saw the safety guard will pivot into the upper shield. As the saw go back up after cutting a piece of wood. The safety shield will drop back into it safety position covering the 12" blade. GB...stewbsion
Aug 23, 2011 | Bosch 12" Dual - Bevel Compound Miter Saw...
Ryobi TS-254 blade guard does not retract when blade is lowered
Probably something jammed up inside the body of the saw where the guard retracts, like a chip of wood. I once had the same problem with my circular saw guard not retracting. Turned out there was a screw that had somehow gotten trapped in there and once that was removed, guard functions perfectly now. Definitely sort it out as soon as possible because this is very dangerous--you could make a cut, rest the saw on your leg and... earn a quick trip to the emergency room.
Aug 11, 2011 | Ryobi Saws
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
How do I lock the motor in to remove bolt and replace blade
If there is not a built in lock for the motor simply use a scrap piece of wood. Pull back the blade guard and place the saw on the piece of wood with the teeth logged into the wood. Apply pressure downward on the teeth and remove the bolt holding the blade in place. You can also use a scrap piece of wood to wedge in the saw between the guard and the blade to prevent it from turning. Be careful and make sure you are turning the bolt in the correct direction.
Apr 16, 2010 | Skil 5500 01 7 1/4" 120V Circular Saw Kit...
I have a Jet planer 15 and the wood gets stuck
I think you are trying to remove too much wood in one pass.Don't cut so deep and see if it will feed thru then. hope this helps you
Jan 17, 2010 | Wmh Tool Group Jet 13" Planer Molder
Gaurd hits before it starts to retract.
does the guard move freely, when pulling down on the handle? or does it **** and seem to hang up. There is no adjustment on the guard that I am aware of but if you are still having problems you can call Makita Tech Support at 1-800-4625482. You will need the model number when talking to them.
Aug 19, 2009 | Makita 10" Dual Bevel Sliding Compound...
Cover will not come up to cut wood
K looked at a breakdown for this tool and it sounds like you are missing a shoulder bolt or roller with bolt that attaches to the lever. Try pulling the guard up by hand (unplug saw first) and watch the side where the cover is for the movement of the lever. Try and locate where it is jumping or the missing part. You can look at the same breakdown at Searspartsdirect.com and by typing in your model number it will come up. It is not really that clear but you will get some idea how the lever/guard work. Let me know if you still have trouble
May 24, 2009 | Craftsman Saws
I have a mastercraft mitre saw. The blade blocks midway when I am
The picture I could get only shows one side. From my experience, these guards operate using leverage, where a little motion results in a lot of movement to the guard. That means a little damage or wear in the linkage can make a big difference. A bushing may have shattered, or a pivot hole may be worn out. Reviews of this machine mention dust not going into the bag. Make sure dust is not jamming the guard works. Take care, having to move a guard while the blade is spinning is scary.
Mar 28, 2009 | Dewalt Mitre Saw Workstation
Makita 10" Dual Slide Compound Miter Saw with Light LS1013F Logo
285 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
