Question about Whirlpool RF364 Electric Kitchen Range
The oven heats up very slowly
Should both top and bottom elements come on during warmup?
  • Whirlpool Master
  • 43,501 Answers
Yes...
Check out this tip that I wrote about this problem...
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 04, 2010
Does the top element turn on during pre-heat on an Kenmore 790.92 range
No, the top element was designed to only work on the broiler setting.
Sep 20, 2014 | Ovens
My oven cooks everything on the top, but not as much on the bottom. The bottom element gets red, but, I'm not sure that it gets as red as the top?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
Jan 04, 2011 | GE JKS05 Electric Single Oven
Convection stopped working a couple of months ago, now regular oven does not come up to proper temperature, top element is red bottom element is not
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 12, 2010 | KitchenAid KESC307 Electric Kitchen Range
It is taking a very long time to preheat the oven. It seems that the top element heats up and then the bottom element heats
heatman101
May 30, 2010 | GE JBP68 CleanDesign Electric Kitchen...
Bottom element is not heating
bottom element need to be replaced,unplug unit,and open the oven and unscrew the screws that hold it inplace,pull it out slowly and detach the two wires and replace with a new one install in reverce order
Feb 16, 2010 | Cooktops
Top oven will not turn on elements, bottom oven turns on elements
heatman101
Nov 10, 2009 | Whirlpool GBD307PR Electric Double Oven
Oven does not heat to proper temperature. Starts at 165 F when before it started at 100 F. Bottom element goes out during warmup.
your temp sensor or oven control board is bad. Temp sensor should have around 1080 Ohm resistance in room temperature.
Oct 13, 2009 | Kitchen Ranges
Element Question
In most ovens, both elements are used during the warmup phase even when used for baking and after the set-temperature is reached, the lower element keeps it stable.
You should be able to detect which one is not working with your bare hand. Set the baking temperature for 250-300 degrees, leaving the oven door open. Hold your hand at different heights in the oven and you should be able to sense which element is working and which isn't within a couple of minutes.
If you still aren't certain, then try using the broil element only. If it is heating, then it's obviously OK and that would point to the bake (lower) element by default.
A final check could be done with an open door and hovering with your hand over the lower element; no heat = defective.
Mar 03, 2009 | Amana AOES3030SS Oven
Whirlpool RF364 Electric Kitchen Range Logo
199 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
