Question about HP OfficeJet 7310 All-In-One InkJet Printer
The glass on the bottom side of my all-in-one
The glass on the bottom side of my HP 7310 Officejet all-in-one needs cleaned - what all do I have to remove to clean it
  • 1 more comment
  • painter8609 Apr 30, 2010
    It doesn't appear to be dust, but looks slightly milky. It seems to make my scanned photos less sharp looking. I have figured out how to remove most of what is needed except for the front control panel. It has a couple of holes underneath, but I'm not sure if they have screws or ?
    I don't see any tabs - I think it has to do what the 2 holes under the front panel, but I'm not sure how to engage them
  • Terry Lennon
    Terry Lennon May 11, 2010
    you shouldn't have too, when you scan does it show up on the scan?
    you can purchase can air compressed, see if you can blow it off before removing the glass
    Scholar:
  • 118 Answers
Just be careful not to damage anything
the front part might be 'snapped' on, look to see if there are any tabs that you could push in to let the front face come off.
Also, if you get to this point of the glass underneath, look in the system to see what may have caused it.
Lastly, most importantly, make sure every thing is UNPLUGGED so you don't ground it out.
Posted on Apr 30, 2010
Testimonial: "Thank you, I figured out how to open the front panel. You are a Blessing!"
  • Terry Lennon
    Terry Lennon Apr 30, 2010
    get a small Philips screw driver and insert in the two holes. most likely these are holes for screws. it will not be a standard screw head type, they use only Philipps head screws
    try that
  • Terry Lennon
    thanks painter8609, have an awesome weekend!
Exactly what parts am I cleaning for a 'carriage jam' on an HP Officejet 7310 printer
the carriage jam error is meaning the path that the printhead is sliding from side to side. You might have a small piece of paper causing an issue.
Dec 03, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Where is the carrriage located on my hp 7310 officejet printer?
The carriage is the unit that holds your ink cartridges, usually parked on the right side. When you have carriage stall or carriage jam you usually need to clean the clear plastic strip that runs across behind the carriage assembly, and make sure there are no scraps stopping the travel of the carriage.
Dec 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
When scanning or copying from either the ADF or the flatbed, my 7310 puts a black line all the way down the right side of the page exactly 1 1/2 inches from the right edge. I have cleaned the glass (and...
You can check the white guide bar that sits above the glass, any marks on there will leave a streak because it is the white reference for the scanner. after that you will probably need a new scan assembly because sometimes single elements will burn out.
Aug 07, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Every time I turn on my officejet 7310 printer a warning comes up saying scanner failure. I cannot do anything with it. I uninstalled it & reinstalled it but with no luck getting it to work> ...
Sometimes you can clean the scanner optics and get a little more life from it, but it involves taking the glass off the top and cleaning the scan unit mirrors and lenses. When that doesn't work you need to locate a new scan assembly, last check, around $150.00
HP Officejet 7310 - Scanner Failure - Can't Remove ADF
These printers are notorious for having bad scanners. The fix will not last long. Replace the printer.
Mar 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP 7310 All-In-One giving a dark line one scans and copies
I had the same problem but figured it out. Both sections of the top of the printer open and under the left side there is a separate "scanner window" that you can't see unless you open that side. lift your regular scan tray and then pull the left side up (it opens out to the left) and then left the piece that is under it. You should be able to see the thin scanner window. You can clean it with rubbing alcohol or even windex.
Feb 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Scans & copies have vertical line through them. I am not using the ADF. I have cleaned the glass & looked at the glass and it does not appear to be scratched. The vertical line is consistent and...
After troubleshooting with HP for about 90 minutes and discussing my lack of enthusiasm at their proposed solution, I purchased a new all-in-on printer.
Nov 04, 2008 | HP Officejet 7310 All-In-One Printer
HP 7310 Deskjet all in 1 printer - scanner problem
try to claen the glass see is there any mark of dust or nay lines of colour just clean it and see
Oct 16, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
206 people viewed this question
Seeker5211
Seeker5211
