Question about Boating
1998 Bombardier Sea Doo leaks, after water gets into the engine compartment it runs badly. Our local seadoo mechanic can not find the leak. Any suggestions? Thanks
    Problem Solver:
  • 15 Answers
Pull out the spark plugs and put the cooling line on the motor and turn on the water see if you have a crack in the cylinder walls or a blown head gasket.
Posted on Apr 30, 2010
Why does my 1995 seadoo bombardier shut completely down while wide open
Very likely a cracked wire on the ignition-advance. As the throttle is advanced so is an advance-lever that causes the wiring attached to it to Flex, causing an intermittant loss of current to the coil/CDI.
The flywheel may have to be removed to repair/replace the wiring.
Aug 16, 2014 | Tempest SeaDoo/Sea-Doo/Bombardier Jet Ski...
Sea doo troubleshooting
check the fuel for water or blocked filter . check that the fuel tank is venting properly
Aug 16, 2014 | Cars & Trucks
I have a seadoo with oil getting into water resavoir what would cause this?
oil cooler under intake manifold do corrode , remove and pressure test ! head gaskets fail , also water pump seals !
Aug 09, 2014 | WSM 2005-2009 Sea Doo Rxt All Models 1503...
What causes a 1993 seadoo engine to bog down then take off, then bog down?
fuel mixing issue. A good tune up is recommended. Focus on the carburetor.
Jun 07, 2014 | Sea-Doo US Seadoo Sea doo pump off 1993 XP...
96 seaboo will not go full speed in water, but full rpm out of water
carbs need cleaning and check the pulse jet that squirts fuel on set off , fuel pump diaphrams ok ?
Sep 08, 2013 | Sea-Doo US Seadoo sea doo cdi ignition...
Seadoo jetski
have you got any fault codes on the screen ? has the intercooler been checked for leaking in to the intake manifold ? press the set button 5 times to see codes if any ! how old is the fuel ? over 5mths then replace !!
Jun 20, 2013 | Boating
Where is the battery located in a mercedes ml-320 2009
The battery on a 2009 Sea-Doo is located in a small compartment located at the back left above the water jet. The Seadoo was a model of personal watercraft produced by Bombardier Recreational Products from 1989 to 20031. The XP is a significant model in that it was the first high performance version of a runabout (or sit-down) watercraft to be offered by any manufacturer. ---------------------------------------------------------------------------------------
Auto HID Xenon Light
Jan 22, 2013 | 2007 Mercedes-Benz ML350
Boating Logo
313 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
