Symphonic television i can't change the channels any farther then channel 27 and it skips some of those in between.i don't have a door that opens with all those little gagets to mess with.can you help me??
  • 74 Answers
Use the original remote, or the menu button on the tv. Press menu. Find "setup" or "channels" or the word cable or autoprogram. Choose cable. Then choose autoprogram or find channels. It will scroll up all the channels and stop in a minute and store them all in memory. The words may be slightly different on your tv, but the procedure will work. Play around in the menus. You will find it.
Posted on Mar 25, 2008
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
How do i get to the input of the symphonic tv model:sc3813
You should be able to access the A/V input by cycling through all available channels (using the Channel Up/Down buttons). You may need the A/V device to be powered on. However, if you programmed the Channel list to skip Aux, you may need to add that back into the list. You need the Menu function on the remote. Use the Up/Down arrows to navigate to Channel Set Up. Then press the F.Fwd (right arrow) to enter the sub-menu. Then select the Add/Delete Channel option.
Another way to access the A/V input is accessed by pressing the Game button on the original remote. (This also adjusts the screen lighting.) The game button is the middle button on the last row of buttons on the remote. If you do not have the original remote, you need one that matches that function. Here is one that is guaranteed to work: http://remotes.com/store/symphonic/sc3813.html . This one may also work: http://www.emtcompany.com/symphonic-sc3813-remote/rc64.html .
The Symphonic SC3813 was manufactured by Funai. The manual is available from Funai service support: http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/ . The direct link to the manual is http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/SC3813.pdf .
I hope this helps.
Mar 01, 2015 | Symphonic SC3813 13 in. TV/VCR Combo
I have a Symphonic model ST420FF along with a Phillips Universal remote. The tv used to work oerfectly but then the channel changed (we have a charter cable box hooked up). Now when I try to change the...
Can you use the menu buttons on the TV to navigate to the control panel to automatically or manually add channels? That would be a start to make channel 3 exist again.
Sep 20, 2014 | Televison & Video
How do I set my TV channel to 3 without the remote?
Hi John,
If channel 3 is skipping by the unit when pressing the channel button key at the front panel, it might be accidentally deleted on the channel selection. If you don't have a remote control, there's no way to add it on the selection. All you have to do is to re-scan the channel by entering to Set-up Menu. Press the Menu button key repeatedly at the front panel to show the "On Screen Menu". Select " EZ Program" to automatically finds and store the channels available at your area. Once the scan is finished, you can now watch all the channels available including channel 3.
Please let me know if you need further assistance.
Kind Regards,
Jdvillanueva
Nov 24, 2011 | Zenith C27A25 27" TV
I accidentally hit the menu button on my tv and seem to have reset something. It goes from Channel 126 directly to Channel 24 and will not set to channel 3, which is the only one that works with my cable
Hello
You have hit the channel skip function to on. Go to menu and come towards functions where you can see channel skip. Keep it to "off" position. Now it is in "on" position.
Oct 16, 2010 | JVC AV-27530 27" TV
Channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Nov 18, 2009 | Philips Magnavox 27MS343S 27" TV
27'' symphonic TV. Sony remote wont work since switched 2 digital
Use the channel buttons on the unit to go down past channel 2, usually you can get to the inputs this way.
Aug 09, 2009 | Sony Televison & Video
I do not have a remote control for my Symphonic tv and I am trying to put the tv on channel 3 or 4 but I can't. It goes from channel 2 to 8. Please help.
Below are some places where you can purchase a symphonic remote control. But if you don't fancy buying one why not tune channel 8 and upwards to the station's that your are after and just forget about the 3,4,5,6,7. My quess is that the tv system is set to skip these channels. If you go to Menu > tv settings, check out the channels that you are skipping, it should be in the installation part of the tv setting's menu. Make sure that where it say's SKIP > OFF on all of the missing channel's.
Hope this is of some help. Bit long winded but hey! :-)
Hughie.
www.remotecontrolscenter.com/symphonic/ -
www.tootoomart.com/buy-symphonic+remote+control/ -
Jun 17, 2009 | Televison & Video
27}" Symphonic
Oh ok, make sure in the menu of the tv is set to Air and not Cable.. that should fix your issue.
Sep 25, 2008 | Symphonic ST427FF TV
Symphonic tv channel search
thru manual search and lock the channel one by one at the memory...
Aug 28, 2008 | Symphonic ST420FF 20" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
