Question about Poulan 14" Electric Chainsaw
Adjustment for carbuerator on Poulan Pro Chain Saw/ Model 221/ 40
I just rebuilt the carbuerator on a Poulan Pro Model #221/40 cc engine.
There are no instructions in the Instruction manual and I don't have an service manual. Is there a way I can get the information on proper adjustments or even site that would allow me access to the service manual? Thanks for any help you can give me.
  • Anonymous Mar 23, 2014
    chain was loose then came off
    Brigadier General:
  • 4,088 Answers
Are the jet screws fitted with slot heads or 'D' heads? 'D' heads require a special tool to adjust and are not available to the general public, so you are stuck with taking the saw to a servicing dealer for adjustment. Slot head screws can be turned with a small flat-blade driver by anyone. In case you have owner-adjustable heads, try the following: Turn both screws CW to stops (lightly), then back each out 1-1/2 turns CCW. The engine should run with this basic setting. Warm up the saw, then pull the throttle full on. Turn H needle CW until the engine speeds up somewhat, but still 4-stroking. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW until the engine idles fairly well, but allows the engine to 'follow-the-throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to run. Hope this helps!
Posted on May 04, 2010
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Chain saw is not oiling the chain
adjust oiler screw on bottom of saw--clean out area behind chain cover
Apr 26, 2014 | Poulan/Weed Eater Poulan Pro 35 cc 16" Gas...
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
How does the throttle cable route on a poulan pro 260 42 cc chain saw
HOW DO I INSTALL AN ACCELERATOR CABLE ON MY 260 PRO POULAN CHAIN SAW?
Oct 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Remove chain guard
The OM for your saw is is the best guide. You can download a replacement here (disengage the chain brake first - pull handle aft):
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
A broad adjustment procedure can be found here. Completely remove the bar cover, slide the bar against the drive sprocket, remove the chain from the bar.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 10, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
JUST BOUGHT A 20'' POULAN PRO TENSION A CHAIN
the adjustment screw near the end of the bar( next to the engine) needs to be turned in to tighten the chain just don't tighten it to much
Apr 04, 2010 | Poulan Pro Chain Saw 46cc 20"
Need chain adjustment wheel part # for poulan pro model pp4620apx chsain saw
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I think this is the what you seek:
http://www.ordertree.com/modelinfo/PWE/PP4620AVX-Gas-Saw/75.PP4620AVX-Gas-Saw.1.59.1.html
The "Handle, Chassis, and Bar Assembly" detail
Items 63 through 69 are parts, I think item 70 is a complete assembly ($22.78 without a kiss).
Your saw without tooless adjustment.
http://www.ordertree.com/modelinfo/PWE/PP4620AVHD-Gas-Saw/75.PP4620AVHD-Gas-Saw.1.59.1.html
Item 64 (complete assembly) $2.53.
If my saw I'd ask if it can be modified!!!
http://www.ordertree.com/cms/parts-lookup-help/73.html
I suspect a vert simple modification. HTH
Lou
Nov 18, 2009 | Poulan Pro Chain Saw 46cc 20"
38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Dec 05, 2008 | Poulan Pro Chain Saw 46cc 20"
Poulan 14" Electric Chainsaw Logo
364 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
