Question about Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
Not making coffee
I started the machine and pressed the button without the water tank attached and now the machine doe not make coffee!
  • 160 Answers
Unplug the machine.
Fill the water tank, and drip a little water into the out-spout to prime the pump.
The auto-off feature is designed to protect the pump from running dry and burning out.
*Some models had a reset button on the rear, if yours has it then use it.
Plug the machine back in and give it a try...once the pump sensor acknowledges water, it will reset.
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 30, 2010
NEED TO GET OUT OF THE DESCALING PROCESS. HOW CAN I DO THAT?
Descaling instructions:
  1. Press the " " button until the CACL CLEAN symbol appears. Press the " " button to start the descaling.
  2. The machine reminds you to insert the carafe and pull out the what is in there dispenser. The descaler symbol appears on the display. ...
  3. Take out the water tank. Pour the entire bottle of Saeco descaling solution in the water tank.
  4. Top up the water tank with fresh tap water to the MAX line. (Please ensure the max line is reached otherwise this will require further rinsing). Place the water tank back into the machine. ..
  5. Place a bowl underneath the milk carafe dispenser and the dispensing spout.
  6. Pull out the milk carafe dispenser to the right up to the " " icon.
  7. Press the " " button to start the descaling cycle.
  8. The machine will start dispensing the descaling solution at intervals. The bar on the display shows the progress. This takes about no moro then 25 minutes.
Sep 28, 2016 | Coffee Makers & Espresso Machines
My nespresso Larissa only drips a small amount when I press the large cup button?
After starting the machine press all 4 lit buttons on the top of the machine simultaneously for a few seconds. That will reset the volumes to factory settings. Decalcify your machine according to the manual provided with the decalcifying kit and the special nozzle for the milk steamer.
If if that does not work fill the water tank and the (clean) milk frother container with the 50/50 decalcifying solution + water and install as usual for making cappuccino (without a coffee capsule). Turn on machine and when the buttons light up press the large cappuccino button. Instead of cappucino you will get hopefully any of the residue from the entire system flushed out. Repeat until you used up the decalcifying solution in both containers. Discard and rinse a couple of times with clear water in both containers. Good luck - worked for my machine.
Oct 11, 2014 | DeLonghi Coffee Makers & Espresso Machines
My maker keeps on saying descale. but how do i do it.
17.3 Descale
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the message:
DESCALE
flashes on the display, you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the P button (the light over the button comes on) then press the button repeatedly until the
appliance displays:
DESCALE No
• Press the button (corresponding to the SET symbol flashing on the display) and the appliance will
display:
DESCALE YES
• Press the OK button to start the descale programme.
• Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one litre of
water.
For subsequent descaling, use descaler of the same type and brand as supplied (available from technical
service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
34 C o l l e c t i o n
• press the OK button.Descaler runs off from the hot water spout into the container below.
The appliance displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
Oct 22, 2013 | DeLonghi Prima Donna Avante ESAM6700...
How to discale the unit
Delonghi EAM, ESAM, ECAM, Nespresso
When the appliance displays the message:
DESCALE
Proceed as follows:
• press the button (the light over the button comes on) then press the button repeatedly until
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
RISRINSING COMPLETE PRESS OK
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Jan 01, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Descale
DESCALE
Proceed as follows:
DESCALE No
DESCALE Yes
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I have a DCR902T coffee maker. The red ON/OFF light is continually blinking, and pressing the ON/OFF button does not turn it off. Disconnecting the coffee maker does not change the problem. No idea what...
This is telling you that it is time to clean the coffee maker. Press the minute and hour buttons at the same time and hold untl the light stops flashing. Take out the water filter and fill the water tank to 10 cups and add 2 cups of white vinegar. Put the water tank back in, without the water filter. Take out the permenant coffee filter. Turn it on and leave it until about half the water goes through. Turn it off. Let it sit for about an hour, then finish the job. Then, run 2 pots of clean water through. You are good. It will notify you to clean your system every 40 pots or so.
Jul 29, 2011 | DeLonghi DCR902T Coffee Maker
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck Mikey@espressomachineexperts.com
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Water does not get to main compartment
try priming the machine ( find the plastic gizmo that came with the machine for this purprose..can you get water from the steam nozzle?..there is an internal water filter that may become clogged if you aren't keeping the water tank clean.
Dec 14, 2007 | Saeco Vienna SuperAutomatica Coffee...
Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black Logo
1,197 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
