Question about Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Installation of grommet on model cwtf 15 ( 1 lwr/2 upr pf
How to intstall a grommet on commercial bunn coffee maker model CWTF 15 ( 1 lwr/ 2 upr pf)
    President:
  • 1,618 Answers
Which grommet, there are several on the bunn models, but the most commonly replaced one is the one for the P. stat. Remove the top panel there are 2 screws one in front and one in back, then lift the top 2 burners off machine that will give you access to the tank.
Posted on May 04, 2010
Bunn cwtf adjust temperature
u must locate the lock bottom to open and re- programs ur temp. settings...
Jun 27, 2014 | Bunn CWTF 15-APS Coffee Maker
I need to ship a 3 burner BUNN CWTF 15-3. How do I drain the water out?
You can take the lid off and unscrew the nut that holds the water tray. Then take a 3/8 hose to siphon the water out of the machine.
Apr 17, 2013 | Bunn CWTF 15-3 Coffee Maker
Bunn coffee maker heating element wont turn off
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Apr 13, 2013 | Bunn CWTF 15-3 Coffee Maker
My Bunn CWT15-APS , PF works well except when i push the start button it only makes a few ounces of coffee. Can you help?
It is possible that the brew volume needs to be set, remove the front panel and you find the instructions to set the brew volume.
Sep 22, 2011 | Bunn CWTF 15-APS Coffee Maker
Cwtf is a contant dripping from the dispenser funnel, how do i fix this?
Inlet valve is leaking.Valve is located by removing front access panel.Can be rebuilt using p.n. 1111.0002 repair kit.You can verify by removing top lid and finding water leaking at fill basin tube.
Dec 27, 2010 | Bunn CWTF 15-APS Coffee Maker
What size breaker do I need to install a CWTF - Twin 4/2? I have 208 volts available. Wattage is 6850.
A 50 amp breaker would be best. To find proper amperage its Watts divided by volts, then multiplied by 1.25 for draw.
Jul 16, 2010 | Bunn CWTF Twin-TC (23400.0047) 12-Cup...
Adjusting the temperature
Our Bunn VPR was delivering luke warm coffee. The problem was lime scale buildup on the heating element. I recommend using a cleaner such as Brew Rite or a vinegar solution. If it still does not heat properly, unplug and remove the heating element for cleaning. This corrected our problem.
Jun 17, 2009 | Bunn VPR Coffee Maker
Bunn CWTF 15 Coffee Maker Overflowing drastically
Have you tried resetting the brew volume(make sure board is not set to lock).
The only other thing I can think of is replacing the timer board, because its not telling the solenoid to stop brewing.
Apr 26, 2009 | Bunn CWTF 15-TS Coffee Maker
Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker Logo
174 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
