Question about Dometic Rooftop RV Air Conditioner
Have a Dometic Penguin on the front of a 5th wheel with mech. controls but compressor only runs for a short time & takes a long time to start again new unit
    Guru:
  • 415 Answers
It sounds like your compressor is overheating and going out on internal overload. It takes awhile for the compressor to cool back down before the overload resets itself and allows the compressor to attempt to restart. This could be a refrigerant problem that could be costly. However, it is very likely to be something less expensive also. First, open up the control section and look for any wiring or connections that appear damaged, loose, or overheated and correct as necessary. The compressor will use a capacitor. When these capacitors fail, they will cause the compressor to overheat and go out on overload. Test your capacitor and replace as necessary. Of course there are a wide range of items that can cause this problem, but these are the very most common (and least expensive) solutions that you can check yourself. The capacitor can be taken to a shop that carries this part and they should gladly test it for you.
If you have low refrigerant or a locked up compressor, it will be costly and you will need to decide (based on age & condition) whether it is more beneficial to you to repair or replace your unit.
Without being onsite with toolbox in hand, I hope this has been very helpful to you moving forward. :-)
Posted on Apr 30, 2010
Ac compressor runs but will not cool
check thermostat, replace capacitors amp compressor to be sure its running if not relay module issue.
Aug 08, 2015 | Dometic 651815 Duo Therm 13,500 BTU...
Dometic penguin air ac
either the fan motor or heat strip
Apr 02, 2014 | Dometic Rooftop RV Air Conditioner
Not cooling
check the and see if the condenser fan is running. you will find it if you take the top off also check and see if the condenser coil is clean. if it is dirty or the fan under the top is not running it will cause the compressor to short cycle on limits or overload.
May 29, 2010 | Dometic Rooftop RV Air Conditioner
Unit won't turn on
WHEN A COMPRESSOR FIRST STARTS TO RUN THERE IS AN INITIAL HIGH STARTING CURRENT(30 AMPS PLUS),BUT THIS SHOULD DROP BACK DOWN TO RUNNING CURRENT PRETTY QUICKLY.IF IT MAINTAINS THIS HIGH STARTING CURRENT FOR A WHILE THEN THIS GENERALLY INDICATES THE COMPRESSOR AT FAULT,BUT!!!!! ALSO CHECK TO SEE IF THE FAN IS NOT SEIZED. DISCONNECT THE FAN ELECTRICALLY THEN RUN THE UNIT. IF THE STARTING CURRENT MAINTAINS APPROX 6 AMPS THEN THE FAN IS AT FAULT!........HOPE THIS HELPS!!
REGARDS........BIGGGAZZ
Oct 15, 2009 | Dometic Rooftop RV Air Conditioner
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
Penguin AC cycling
Did you try contacting Dometic directly, to speak to a technical assistant. ( www.dometicusa.com )
Jul 09, 2008 | Dometic Rooftop RV Air Conditioner
Compressor on ac unit
It could be a relay for the compressor is sticking in the run position.
If it is only about one week old take it back to the dealer for service or call them and tell them your problem. This should be covered by warranty and the dealer can refer you to someone authorized to do the work.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
116 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
