Question about ASUS M4A77TD Motherboard
Asus mobo flashes on startup, no video
I have an Asus M4A77TD mobo. On startup the green mobo led is on, but the front panel led flashes with no video.
What is the problem? Where can I find a list of Asus mobo error codes?
  • fester462 May 01, 2010
    Ultimately what fixed the problem was plugging the ATX12V back in after installing the CPU heat-sink/fan.
    Scholar:
  • 83 Answers
You should unplug the power cord from the power supply, pop out the cmos battery, switch the bios reset jumper to the 2 and 3 pins, wait about a minute, put the jumper back to 1 and 2 pins, put cmos battery back in, plug in power cord to psu and turn on pc. If you have any issues with this process please refer to your owner manual for the motherboard or look one up on their website. Please let me know if this fixes your issue.
Posted on Apr 30, 2010
Testimonial: "Although this ultimately didn't fix the problem, it made sense and got me to the source of the problem. "
Front audio port on chassis not working.
This port will only work if it is connected to the motherboard using the case fly leads. To check the correct socket on the motherboard, look in the manual (available on the ASUS website)
May 12, 2013 | ASUS M4A77TD Motherboard
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
Dell Asus M2N61-AX MB front panel connector Nix ATX Gaming case
I assume you mean the HDD,reset,on switch etc where they plug onto the mobo.
Most mobos are labelled on the board but you will need good eyesight to read. They are labelled HDD, RESET, SPEAKER etc.
If not simply look up mobo manual from vendors site. You will need the DELL serial / part number from the old unit though.
Apr 29, 2010 | ASUS Computers & Internet
Acer Pc Tower Extensa E210, p4p800vm motherboard connection probl
So I have found the answer myself ;o)
I removed the front panel of the computer, behind the panel the wires were labelled, I connected the cables to the connectors that I required and connected them to the MoBo, works like a dream!
Jan 05, 2010 | Acer Computers & Internet
ASUS P4XP-X won't energized after minimal repair
Either the board was damaged during the repair attempt, or was bad to begin with. The original problem description (black screen) sounds like typical mobo "no boot" trouble. The loose heatsink on the chip may have contributed to the failure, or it may have been simply coincidence. Given the low cost of motherboards, it's silly to spend any more time on attempting to diagnose and repair a problem. Just replace the board and move on.
May 10, 2009 | Computers & Internet
Unpluging 4 pin power on mobo Pc starts but no video,keyboard etc
how do i fix the monter I tryed to put the power and rest on and motherboared comes on not the monter
Mar 13, 2009 | ASUS P4SGX-MX Motherboard
Soundmax microphone error
Check your front panel connectors are wired correctly :)
Nov 14, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
It doesn't turn on.
Here is the manual for it http://dlsvr01.asus.com/pub/ASUS/mb/sock370/815ep/cusl2-c/cusl2c-104.pdf Usually the light should stay on when its on and off when off, typically if it flashes, the powersupply itself is shutting off and coming back on. I would replace it first and go from there becaquse these LED's dont have a flash feature for this mobo.
Sep 17, 2007 | ASUS Intel 815E Chipset CUSL2-C...
ASUS M4A77TD Motherboard Logo
384 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
