Question about Whirlpool GEW9250 Electric Dryer
I have serveral outlets not working
I was cutting my hedges and cut the cord and several of my outlets are not working and my dryer will not heat
  • 185 Answers
Check the thermal fuse
Posted on Mar 25, 2008
I accidently cut the electrical cord while using the black and Decker hedge trimmer TR116, now its not starting.
Did it cut it all the way through.? Have you repaired it? Has it been repaired adequately? Check it hasn't blown the fuse in the plug when it was cut, protecting the circuit.
May 14, 2016 | Garden
Cut the electrical cord on craftsman electric hedge trimmer. Does not run. Is there a reset ?
NO, no reset. The only thing causing it to NOT RUN is an OPEN circuit condition caused by the cut wire, OR an IMPROPERLY made splice, OR improper replacement of the cord!!!!!
Get somebody that KNOWS what s/he is doing to replace the damaged cord.
Jul 12, 2014 | Craftsman Garden
Have cut through power cable on a brand new hedge trimmer .
open the cover and replace the cord buy a extention cord cut the end off it and use it as a new wire
Apr 06, 2012 | Garden
Dryer is cool not getting hot?
1. Close the dryer door and press the "Start" button for at least one second. Some dryer brands require the button to be pressed for several seconds. If the drum tumbles, you can eliminate the possibility of a problem with the electrical circuit that supplies the motor.
2. Check all the connections on the back of the dryer. Many dryers have two electrical circuits--one for the heat and one for the tumbling motor. If the motor works, but there is no heat, check to see if the larger plug is plugged into its receptacle. Your dryer may have two plugs--one small regular household plug and one larger 240-volt plug for the heat. Both must be plugged in for the dryer to work properly. The larger, three-pronged 240-volt plug will not fit in a normal household outlet; it needs a special dryer outlet. The plug cannot be cut down to fit.
3. Check the circuit breakers or fuse panel if the dryer runs but there is no heat.
Jan 14, 2011 | Maytag PYE2300AY Electric Dryer
NO HEAT . I CHANGED THE HEATING ELEMENT,
Check to ensure you have 220v A/C to the dryer.
The dryer will run on 110v but will not heat.
Ck. the dryer cord where it connects to the dryer.
Some times one of the terminals on the cord may have burned up due to a bad connection.
Electric dryers are not sold with power cords since there are several different types of 220V outlets.
You may have a bad house fuse, Circuit breaker or 220V outlet.
Jan 16, 2010 | Dryers
LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Jan 12, 2010 | LG DLE2514 Electric Dryer
Hedge trimmer not delivering enough power
Check the condition of the 'spark arrestor' screen on the outlet of the muffler. clean with a wire brush and re-install
Oct 18, 2009 | Garden
I cut through the cord by accident, can I buy a replacement wire?
If you are handy, you can do this. Most trimmers some with a very short cord to which you are expected to attach a extension cord. What exactly did you cut? If the short cord that may have come with it ... disassemble the body of the machine and reconnect a shorter (the one you cut) cord. If it was the extension, that is easy. New ends available ar your hardware store.
If there is a trick part,it is in reassembly. Pay attention to how it was configured when you took it apart.
hope this helps
Jun 30, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Trimmer safety problem
# Keep all people and animals away from the area you're working in # Hold the hedge trimmer correctly using both hands # Make sure the hedge trimmer's switched off and idle before attempting to remove any jammed cuttings # Wear protective clothing including heavy-duty footwear and safety goggles to protect your eyes from flying cuttings # Electric hedge trimmers: Don't use in wet weather. Keep the cable well away from where you are cutting and check that the socket outlet has working RCD protection # Read the manufacturer's instructions before use
Aug 27, 2008 | Walter Drake Garden Groom
Whirlpool GEW9250 Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
