Screen items are too large how can i make them
  • 249 Answers
Hi! Try these steps. Right click the blank part of your desktop. Click properties. Then click the Settings tab. Choose a higher resolution on the slider and click apply then ok. Hope this helps.
Posted on May 02, 2010
My maytag front loading washer door sounds Iike there is a loose bell inside..has something come loose?
I had somewhat of a similar problem. What I found was that over time you have coins and other things that get into a washer. These items are than pulled into the drain pump. Most drain pumps have a basket that collected these items. In fact they can get into the pump whereby you will get a lot of noise and this pump is located very close to door (just below it toward the front of the machine). Before starting this operation disconnected the power and turn the water off and take the bottom front panel off and you will see a large white nut. Unscrew this large nut and this will display the screen for catching the loose items in your pants pockets. Clean this and you should be in luck
May 19, 2012 | Maytag Neptune MAH5500B Front Load Washer
How to change text size to be larger
This depends upon what program you are running.
If you mean the Internet, you can change the view settings on most browsers by zooming in (go to "View" in your toolbar).
If it's a Microsoft application like "Word" or "Excel", you can increase the font size or the magnification of the document - again, from the toolbar.
Mar 03, 2011 | Computers & Internet
Would you know how to get rid of the WEbroot Desktop Firewall-Application Control large sign that is right in the middle of my computer screen--It makes it hard to do e-mails
Go to start menu then run type in MSCONFIG then go to startup items. Disable the on screen application for the firewall but not the firewall itself it should stop posting the application on the screen shot. Do not delete just disable startup item. I would also disable anything else that is annoying you a well. It will not hurt your computer. Thanks for using FixYa! John
Feb 22, 2011 | Webroot Desktop Firewall (667208542109)
I have problem with display it get large and it is not coming down on the last position
ON YOUR DESKTOP SCREEN ( ANYWHERE ON THE EMPTY SPACE) RIGHTCLICK THE MOUSE
SELECT PROPERTIES
SELECT SETTINGS ON THE TOP
BELOW THERE IS SETTING SHOWING SCREEN RESOLUTION
YOU CAN DRAG THE POINTER TO RIGHT TO DECREASE THE SREEN ITEM SIZE.
Dec 16, 2010 | ViewSonic Computers & Internet
Lg inverter 75kg wd1238c problem, after before getting to the spin stage of the wash, it stops and the screens says UE on it and UE is flashing on and off
Error code UE cause : Load is too small, load is out of balance( 1 or 2 large items) solution: Add items to help balance the load, rearrange load to allow proper spinning.... Hope this is useful .....
Sep 18, 2010 | Washing Machines
Size of the item is too large
Print acts according to settings in print properties
Dec 16, 2009 | Roxio PhotoSuite 7 Platinum for PC
Icons are to large for my screen
Right click on desktop,
select Properties,
click settings,
adjust the screen resolution,
click apply,
if not better then try different resolutions until you find the icons are the right size for you and the desktop is the right shape (ie not stretched and not black areas around the edges
Sep 20, 2009 | HP Pavilion dv6000z Notebook
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
BTS out door Installation
I have no idea about how to install the actual device but I have read and tried mounting equipment out of doors and have these suggestions. I would get a rubberized food storage container that the item will fit into and a lid would close on it without problems. No gaps in the lid. I would cut only the holes I need for the connections to the item, put the item in the food storage container and take silicone caulk to seal around the holes used for the wires to connect to the item. If you had to cut a bigger hole for a large connector on a cable, use household window screen to fill in the hole around the cable and then use the silicone to coat and attach the screen to the food storage container
Much good luck.
Nov 10, 2008 | Computers & Internet
GE Microwave Model JVM1650
the diode is open when the voltage arive at the anode junction it locks off due to the diode is not passing the voltage,change the diode and the microwave will resume operation.good luck.
Aug 04, 2007 | GE JVM1650SH Microwave Oven
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
