Question about Garden
OVER REVVING HONDA YARDMAN, NEED EXPLODED VIEW OR INFO IDLE ADJUST ACCESS. new fuel, clean plug, air cleaner off, plug chop black. indicating excess fuel. any solutions out there, thx, duncan
  • 64 Answers
It sounds like the govenor control isn't woring or the throttle on the carburetor is stuck. there is an idle adjustment screw on the top of the carb to adjust the idle.hondas are usually a black plastic philips head.
Posted on May 01, 2010
How to adjust idle 2005 Honda 150 dirt bike
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to Adjust Idle On Dirt Bike Tips and Tricks 1
How to tune CRF150F dirt bike other basics
CRF150F service manual repair 2003 2013 CRF150 Download Manuals Technical $10
http://www.partsfish.com/page/oem-parts-for-honda
Honda 2004 CRF150F Owner Manual
May 29, 2014 | 2005 Honda CRF 150 F
Adjust idle on honda shadow
Adjusting the Mixture Screws
Honda Shadow VT700C Running Lean Fix Pilot Jet Needle Shim
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Oct 18, 2013 | 1986 Honda VT 500 C Shadow
1995 Honda VF 750 C Magna poor gas mileage
Hi, Anonymous and the usual suspects are:
1. Excessive enrichner use.
2. High-speed riding style.
3. Idle speed improperly adjusted.
4. Dirty air cleaner element (may also affect idle speed).
5. Restricted fuel tank vent system.
6. Vacuum piston assembly malfunction.
7. Excessive accelerator pump output.
8. Plugged or restricted bowl vent.
9. Fuel level too high.
10. Loose carburetor jets.
11. Worn or damaged needle or needle jet.
12. Enrichner valves not seated or leaking.
13. Plugged air jets or passages.
Average mpg for 3rd gen Magna
http://www.magnaownersoftexas.com/forums/index.php?topic=3383.0
Honda Magna VF750C Service Manual
Honda 1995 VF750C Magna Owner Manual
Oct 05, 2013 | 1995 Honda VF 750 C Magna
2007 Honda CB600F Hornet idle adjustment
The engine should be at operating temperature with the choke off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air-fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air-fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air-fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air-fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda Hornet CB600 locating the idle adjustment tap
Adjusting Idle Honda Hornet 600
Honda 1998 CB600Fw Shop Manual
Honda CB600F Owner Manual
Jul 12, 2013 | 2007 Honda CB600F Hornet
2005 Honda CRF 450 R idle adjustment
Hi, Haselhuj you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
Idle adjustment screw
Honda CRF450X 2005 Service Manual
Honda CRF450R Owner Manual
May 28, 2011 | 2005 Honda CRF 450 R
2000 vtx 1800r running rich at idle...spark plugs black with soot.
Have you changed the oil lately? If there is to much oil in the motor the bike will push oil up into the airbox and foul the air filter out. This will cause the bike to run rich. check the oil level and then drain any excess out to the proper level. You will need to clean or replace the air filter in order to make the bike run well.
Steve
Jan 02, 2011 | Honda VTX 1800 Motorcycles
I have a 1980 gl 1100 goldwing. Up till recently been averaging about 45 mpg or so now it has dropped to about 15 mph. Carbs are sync. and clean. Fuel pump and filter in good working order. Wondering if...
Hi Birdmanofjax, and the usual suspects are:
5. Vacuum piston assembly malfunction.
6. Excessive accelerator pump output.
7. Plugged or restricted bowl vent.
8. Fuel level too high.
9. Loose jets.
10. Worn or damaged needle or needle jet.
11. Enrichner valve not seated or leaking.
12. Plugged air jets or passages.
For more information about your issue please visit the websites below. Good luck and have a nice day.
1980 Honda Motorcycle Service Repair Workshop Manuals
Sep 21, 2010 | 1980 Honda GL 1100 Gold Wing
Need to adjust my honda shadow 500 vt carburator's fuel/air mixture
start by synchronizing your throttle plates. Honda calls the next step the "idle drop procedure". u need to know if you have fuel adj. screws or air adj. screws. fuel screws will be on engine side of carb slide, air screws will be on airbox side of carb slide. start leaning out mixture, (turn in fuel screw, turn out air screw. idle will increase so keep adjusting idle back to spec.after each turn if needed. Adjust about 1/4 to 1/2 turn at a time on each carb until there is no change in idle, then richen up mixture by one half turn. If u sync throttle plates first then follow this procedure, there should be no hesitation when you "blip" the throttle, and after revving it should return to idle smooth,
Apr 08, 2010 | 1986 Honda VT 500 C Shadow
2008 Honda VT 750 Shadow Aero carburetor adjustment
Hi, Rockin_hick1 you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
idle screw air fuel mix
2008 Honda Shadow Aero Idle Problem
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
Feb 02, 2010 | 2005 Honda VT 750 Shadow Aero
Can u pleae help me with my car i have a 1991 honda accord the idle revs up and down when im stoped how do i fix this please
1 . check the fuel filter, maybe has some dirt inside.
2. clean the air filter or put another new air filter in
3. adjust the idle.
4. if there is no way to adjust the idle manually, you need to take to the dealer for computer adjust the idel.
Jul 27, 2008 | 1996 Honda Accord
Garden Logo
113 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
