Question about Kenmore 24 in. 16032 Built-in Dishwasher
The dishes/glasses on the top shelf are not getting clean
Glasses have grainy debris left in them..food(for ex bis of rice) are nt washed away Have tried running on pots and pans still grainy ..note these are not dried or cooked on food particles..kind of like sand not washed away thanks
    President:
  • 949 Answers
Here is a link to a procedure I put together to clean out your pump. A plugged up sump is the most common reason for poor washing on the upper rack.
Let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on Apr 30, 2010
After a full cycle the dishes are covered with pulverized food on top shelf only.
Most (if not all) dishwasher have a food grinder in them just like a "garbage disposal" in your sink. (It's NOT really meat to be a garbage disposal)
In any case if the ground food is ending up back in the washer it means its not being flushed out when the washer empties.
You will need to remove the bottom rack and the bottom spinner. Open the pump and clear any debris The round tank tat the lower arm sits on should also be cleaned out. If the washer is over 5 yrs old consider replacing the impeller and all the pump hardware also.
Without specific Make and Model I cannot give you detailed instructions or parts #s. When asking about things like this alway have the make and model # Good luck
Jan 22, 2017 | Dishwashers
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
There is so much debris left on the dishes after the dishwasher has run, it's almost not worth running it. The debris is mostly small hard bits on the inside of glasses from the top shelf. Is this a...
this is a maintenance problem.. if the bits look like grains of sand it is actually food particles that breaks down during the cycle spraying the cups and glasses (usually the top shelf that gets hit worst). solution is to run a dishwasher cleaner through the system on a hot wash. To remove and wash bottom filters and spray arm jets. Lastly when loading the DW make sure excess food are scraped/rinsed off ...you will get better results. Thanks
Jun 22, 2010 | GE Dishwashers
Food remnants left on top rack of glasses and ceramic mugs.
Before loading into the machine clean the particles that are sticking to the dishes.
Check the drain filter at the bottom rack and clean. It is user cleanable
Apr 06, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Oct 09, 2009 | Dishwashers
My Bosch Dishwasher doesn't clean
Check the following to address this issue--
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 02, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dirt left on dishes on top tray; bottom tray washes fine
The broken bottom arm is probably preventing any water / water under pressure to get to the upper arm.
After you replace the lower arm, you should have much better cleaning in the top shelf.
While you are in there replacing the lower arm, recommend you remove the filter under it and clean the filter and any debris you find. Be careful of broken glass!
Good Luck!
Apr 03, 2009 | Dishwashers
Food particles are left in the dishes on the top rack of the dishwasher. I have checked for debris clogging the spray arm but there isn't any. I have to wash my glasses on bottom rack to make sure they are...
is this a bosch dishwasher? if so then check my recent post about that here.
http://www.fixya.com/support/t1713479-bosch_dishwasher_top_row_dishes_not_get
Mar 18, 2009 | Dishwashers
Kenmore 24 in. 16032 Built-in Dishwasher Logo
498 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
