Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
The hose works great, but when I try to vacuum the carpet it doesnt work. The brush is turning, but I don't feel much suction. I checked for a clog and didn't see any.
    Sergeant:
    Champion:
  • Dyson Expert
  • 357 Answers
You probably need the clutch replaced. This needs to be done every 1 to 2 years for most people
Posted on May 01, 2010
My dryson dc40 beater bar will not spin and there is no suction
The brush bar motor or one of the switches may be defective. If the brush is not spinning it will not pick up anything from carpet leading many to think it has no suction. Feel for suction down by the brush bar. If you have no suction it may have a clog or need new filters. Make sure the changeover valve that switches suction from floor to tools is working properly.
Mar 25, 2018 | Dyson Vacuums
Very low suction when I use the hose, but the carpet brush roller attachment works fine. Any ideas?
This style of vacuum has great airflow but does not have great suction, especially at the end of the hose but it still should have enough to pick up most soils. It may have a restriction in the suction tube or emptor. The disposable bag may be full or clogged, the outer bag could also be clogged.
May 04, 2016 | Kirby G4 Bagged Upright Vacuum
Loss of suction from base but ok from hose. filter cleaned and dried
When the Cyclone Assembly on the Dyson is not spinning around, it usually means that you are loosing suction somewhere. This can either be caused by a clog, suction leak, or dirty filters. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem # 1. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the vacuuming position with the handle down. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the handle was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
hope this helps you .........
Mar 11, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell proheat tubrobrush pet not suctioning?
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your bissell vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Bissell replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 03, 2014 | Bissell Vacuums
DC17 suction motor stopped
It could be that your cyclone needs to be replaced. Depending on how the unit was cleaned (the cyclone in particular). Some people who service these machines wash the cyclone with out completely dismantling it, they just fill it with water and shake stuff out of it. This can cause debris inside the cyclone to become lodged causing clogs. If after checking for clogs and if your changeover valve is working (the piece that moves back and forth on the side of the machine when you pull the handle back to vacuum carpets) and the machine is in the upright posistion and the hose doesn't work, then you probably have a cyclone problem.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 10, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
No suction in carpet cleaning mode with Empower
Check the nozzle . Turn it over on it's belly and remove the 4 screws that hold the base plate on. Take off the plate and remove the brushroll. I bet you will see a clog in the intake. If not take it to your local vac shop and let them fix it.
May 28, 2017 | Hoover U5262-900 / U5260-900 / U5266-900 /...
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Suction only works using the hand held mode, there is no suction when try to use on carpet mode,
There must be a clog in either the hose, dirt inland by the brush roll, or bad filters. If you have suction at the end of the hose, then look lower all the way to the brush roll.
Mar 25, 2008 | Vacuums
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
154 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
