Question about Compaq Armada M300 Notebook
Halp of the laptop
How to go in bios in compaq armada m300 i will trey all kine of key to go in bios it's not working then plz help me
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    you can do this , during start up by pressing F2
    Brigadier General:
  • 6,966 Answers
with the indulgence of IB4G2008, you can try Fn + F3.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 25, 2008
My computer COMPAQ ARMADA M300 show this message: PXE-E61, and then Window XP star but after this do nothing.
You should follow the below steps sequentially in order to isolate the cause and solve the issue:
  • Verify all the cable connections of the hard disk. An improper or loose connection is likely to be the reason, in case the hard disk has been recently installed or moved.
  • Check if no other storage device is connected to the computer. If it is, remove it.
  • Enter the BIOS setup when trying to start the computer and see if hard disk has been correctly setup and detected in BIOS. If the hard disk cannot be detected due to any reason, you should consider the next suggestion as it might be physical failure.
  • Replace the hard disk and restore the data, provided a good backup is available. In other circumstances, you should consult a company that provides data recovery services. These companies have efficient tools and staff to perform hard disk recovery and extract valuable data securely.
Wish you luck,
Lucas
Jul 08, 2011 | Compaq Armada M300 Notebook
Bypass BIOS setup Password
Pull out the CMOS battery (the little watch-style battery on the motherboard). This will reset all of your BIOS settings including the password.
Mar 14, 2011 | Compaq Armada M300 Notebook
How to replace the USB controller to a high-speed usb controller
Simple.... buy a new laptop.... no other way as it is built into the board and programmed into the bios.....
Mar 03, 2010 | Compaq Armada M300 Notebook
My compaq armada m300 wont recognise new hardrive
just try with fixing the hard drive connection properly and in bios also check how much capacity motherboard can support .according to your specification it will not support the higher capacity hard disk .make sure you installing the new hardidsk as same capacity of your older hard drive.
Nov 25, 2009 | Compaq Armada M300 Notebook
I got ahold of an old Compaq Armada M300 but it has no operating system. I tried installing Ubuntu and Xubuntu but it says that the bios age 1999 cuts off at 2000. I downloaded the BIOS update from compaq...
Borrow a USB floppy drive, copy the update on a floppy disk. You will need a floppy to update the BIOS of the old computer anyway. Reviving a defunct machine with Linux is a worthile endeavor.
Hope it helps.
Aug 31, 2009 | Compaq ARMADA M300 11.3" Flat Panel LCD...
I have a Caompaq Armada 7770 DMT that is set to fast boot
om my armada m300 before the boot screen comes up i tap f10 a few times to get in service mode, it mayy not b f10 on urs though, may b f3 or similar.
Apr 11, 2009 | Compaq Armada 7770DMT Notebook
Compaq
I don't think that version has WIFI. You can find the manual for it here.
http://dl.owneriq.net/b/b93bfeaa-7290-44a5-8a4f-d2b10a651de1.pdf
Please don't forget to rate me.
Feb 01, 2009 | Compaq Armada M300 Notebook
Compaq Armada M300 Loose Display Screen
There is no adjustment on the m300 v300 m700 v700. These hinges will have to be replaced. I do have a set from an v300 am not sure if they are compatible but you can have them if you want.
Mar 18, 2008 | Compaq ARMADA M300 11.3" Flat Panel LCD...
Boot up with no operating system
When the system starts, hold the F10 key and go into BIOS and set CD Rom as 1st Boot device (in Boot Order). Because most Compaq's would put the BIOS in a hidden NON-DOS partition on the hard drive, you may have to get an OEM recovery disk for that model. Because there is no BIOS to go to, the machine doesn't know it has a CD, HD or Floppy to go to. A boot floppy/CD is no help. Alternative 1: With another desktop and IDE to Laptop HD connector, FDISK (make active partition and hidden partition [5mb]), Format both, copy the cabs from WinME CD to c:\windows\options. Alternative 2: Find the COMPAQ OEM CD for that model. Since there was no exact model number Click here Please indicate whether this is helpful or not.
Oct 28, 2006 | Compaq Armada 1750 Notebook
Compaq Armada M300 Notebook Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
