Question about Whirlpool Duet GHW9150P Front Load Washer
Dryer doesnt get hot anymore after 2 yrs
My dryer doesn't get hot anymore. it takes 2+ hrs to dry small loads
  • 5,911 Answers
You may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you don't have any clogs. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back an let me know. I hope you find this information helpful.
Posted on Apr 30, 2010
The dryer turns on seems to work fine except it doesn't heat. Takes at least 2 hrs to dry a load.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';';
Jun 29, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore dryer 90 series, heats a little, but doesn't get hot and takes 3 to 4 1/2 hrs to dry a med. size load.
Check vent path from lint filter all the way to the exhaust vent to make sure it is clear. If the dryer has a wet/dry sensor it could be malfunctioning. Try a manual cycle to see if the problem occurs then.
Jul 18, 2009 | Dryers
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Dryer not drying clothes anymore!!
Get the power company to send a repairman out there. The power surge mess up the controls.
Apr 09, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer gets hot and tumbles, but load takes 2 hrs to dry complete.
That means that there is a problem either with the vent , or the heating element, or the thermostat, rarely this can also be caused by a defective control.
Ususally this is a heating/thermostat, or a ventilation problem.
See also Drying is too slow.
Dec 18, 2008 | Kenmore 62802 Electric Dryer
Clothes aren't drying properly
look behind dryer is vent hose kinked or mashed flat? ck a load with hose completely disconnected may get warm and a little dusty but if problem solved reck hose all the way through
Nov 17, 2008 | Frigidaire Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
