Question about Kenmore 99123 Electric Kitchen Range
I have a Kenmore Elite electric range smoothtop model 790.96593. The middle burner of a three burner option does not work. The other two burners outside of the middle burner is working. Is there anything I can do other than call Sears and pay a lot of money? Murray
  • 5,911 Answers
Yes, you can repair the appliance yourself and save on the cost of labor and services charges. Unfortunately, when these triple burners go bad in the manner you describe, there is no way to repair only the portion that is burned out. The burner is one complete piece and needs to be replaced as an entire assembly. The following link explains how:
http://www.fixya.com/support/r3692628-surface_burner_replacement_electric
Replacements parts can be purchased from any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. I suspect your model number is actually 790.96593601 or 790.96593602. These are the only two numbers that cross to the model number you provided. If I'm not correct, please post back with your COMPLETE model number.
The part number for the triple burner is 316216702. Keep in mind, this part, alone is not cheap. The cheapest price I found was about $120 at appliancepartspros.com. However, you would spend much more if you included the added price of a service call and labor charges. Use the part number provided to search any other web sources you like to see if you can find the burner listed elsewhere for a better price. Use the part number as some websites may not list your particlar model, but will carry most parts.
If you have any questions please post back and let me know. I hope this helps you.
Posted on Apr 30, 2010
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
My kenmore electric smoothtop range's oven doesn't work. Broiler and burners are fine. Any help?
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | Kenmore 96532 / 96534 / 96539 Electric...
I am trying to replace a burner on my amana smoothtop electric range. I have removed the three screws above the overn door (inside). The top is loose but something seems to still be holding it. Any...
most ovens usually have 2-3 screws located along bottom edge of the smoothtop in the front..check the far left and far right corners in the front /if all screws are removed,you may need to pull slightly forward then raise
Mar 06, 2010 | Amana AER5715QAS Electric Kitchen Range
My PLEFMZ99GC is showing an
Please read this article... it appears our model is under recall by Fridgidaire. You should probably contact the manufacturer right away to see what should be done...
http://www.appliance.net/2009/recallfrigidaire-and-kenmore-smoothtop-electric-ranges-due-to-fire-hazard-1369
Oct 25, 2009 | Frigidaire PLEFMZ99GC Electric Range
Middle section of element on smoothtop stove not working
yes you can
goto appliancepartspros.com
type in your model number
under the section top
you will find your part number...
when it arrives unplug the unit and remove the screws holding the top down under the froont lip
lif the lid and mark where your wires connect, remove the wires, and the two 1/4 scres holding the burner
sometimes 4
switch out the burner, and re plug all your wires
drop the lid and test
Oct 15, 2009 | Kitchen Ranges
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Corning smoothtop electric range
You MUST use flat bottom pans on three of the four burners, the back right burner is the multi-pan burner and accepts any type pan. You'll notice the other burners have a circle in the center, that is the thermostat that reads the temp of the pan, that burner type needs the flat bottom pan to work correctly. The multi-pan has no thermostat and it will boil water in any pan.
Good luck
Jan 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Kenmore 99123 Electric Kitchen Range Logo
1,187 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
