My computer had a problem and I had to do a recovery...it has wiped everything I had off. Is there anyway to get it back if I didn't create backup discs prior?
  • dizzielizzie Mar 25, 2008
    It has all the programs etc... it has just lost all my saved files
My sis 630 ctn doesn't work, after install win XP then trouble won't boot again
Posted on Mar 25, 2008
Restore recovery disk
Hi Billy,
depends on what you mean by restore. Assuming you have windows installed, you can make a back-up by going to START > Control Panel > System and Security > Create a backup
(the path above may be a bit off from the wording, the PC I am on at the moment is not an english version.)
Then on the left side there is a link to create a recovery disk or create a backup. the recovery disk option only makes a bootable disk to start your computer if your windows cannot start. This only gives you an enviroment where you can try to fix windows or to restore a backup that you created beforehand with the second option above.
If you create a backup, there are two things to keep in mind... what type of data do you want to back up and how often. You can put check marks on all data that you want to backup (Note: the more data you backup the larger your backup file will be). If you plan on restoring a corrupt windows with the backup you should include "System State".
Restoring from a backup file a.k.a. backup image will ONLY give you back the files that were on your computer at the time you made the backup... that means everything that you created after you made the backup will be lost.
Hope that helps.
May 16, 2014 | Dell XPS 200 PC Desktop
Tip
How to hard reset your samsung s7 or s7 edge
How to hard reset Galaxy S7 and S7 edge
Please note that hard resetting erases all the data on your device. Text messages, photos, videos, settings, everything will be removed in the process. So, don't forget to create a backup of your Samsung Galaxy S7 or S7 edge before proceeding.
Also make sure to juice up your smartphone to at least 60% or keep it plugged in during the process. You don't want to have your device turned off when you hard reset Galaxy S7 or S7 edge, or it will create further issues.
Factory reset Galaxy S7 or S7 edge the easy way
  • Open the Settings app.
  • Choose Backup & Restore > Factory Data Reset.
  • Now select Reset Device > Erase Everything.
  • Confirm the warnings and wait for the process to finish.
  • Once done, reboot your phone.
Hard reset Galaxy S7 or S7 edge using recovery mode
  • Power off your device.
  • Wait for a few seconds while your phone is shutting down.
  • Press and hold the Power, Volume Up and Home buttons simultaneously to get into Recovery mode. (read: how to get into Galaxy S7 or S7 edge recovery mode)
  • Use Volume keys to navigate and Power button to select an option in Recovery mode.
  • Once in, from the main menu, using Power key, select wipe data factory reset.
  • If you want to clear app data cache too, choose wipe cache partition. Clearing cache often fixes various software related issues.
  • When done, go back to main recovery menu.
  • Select reboot system now and that's about it.
Hope the above tips help you fix Galaxy S7 issues and bugs.
on Jan 16, 2017 | Cell Phones
I have acer spire 5745(CPU intel i5 processor 2.5GHz RAM: 6GB OS:Win 7 Home basic) which is 1.5 year old. Yesterday i started acer eRecovery then i can not create operating system recovery disk, but
Unfortunately for you, you didn't follow the Acer instructions. The recovery disc must be created before you start using the computer or making modifications.
There is a remote possibility that if you go into control panel and click on 'restore' and go back to the earliest date, you can then run the recovery disc. Remember that this only a remote possibility and I make no promises.
May 04, 2012 | Acer Aspire Computers & Internet
I caNT RESET MY FACTORY DEFAULT SETTINGS FOR MY ACER ASPIRE 3680 COMPUTER
How to restore your computer to factorysettings without a disk?
If original andfairly new: While Booting Up.
Dell XP = Ctrl+F11
Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. Also if it didn't come withdisks there is normally a program in the menus to create your own set of recovery CDs. This must be done before you ever putanything on the recovery partition d:, if you used d: for anything you need toremove what you put there or the recovery will not function.(As soon as yourcomputer is turning on press the F10 key and it will take you to the systemrecovery screen, click on the advanced option and click Destructive recoveryand click next. WARNING: before doing this backup anything on your computer youwant to keep pictures, videos, music etc. This will delete everything that didnot come pre-loaded from the factory, so if you have pictures of Aunt Fae'sClass reunion you should probably back those up if you want to keep them.)
Oct 22, 2011 | Acer Aspire 3680 Laptop
I need to get my toshiba nb200 sp2903r to factory settings and i havent been able to do it
What you intend doing can only be achieved by formatting your PC.
After doing that, you would have to re install the operating system(OS), or another OS, then install the recovery drivers.
Formatting of your system is not what you wake up and perform overnight, because doing this wipes out EVERY information you have on the PC. So before doing this, you would have to backup your files.
Also, since it wipes off all yor installed driver, you either ensure that you have a recovery disk, or you create one.
If you have a recovery disk partition on your system, backup your drivers to it. Other wise, you can use an external disk as your recovery disk.
After doing that, you right click your hard drive, that is the one you are using; the one containing your program files, and click on format.
You can access the backup by typing 'backup' in the start bar, and hitting enter. It would then provide you with the steps to back up.
NB: Make sure you dont back it on to the drive your use, ie the one containing your program files, because the format process would wipe it off.
I hope that helped?
Have a great day.
Jun 03, 2011 | Toshiba Satellite A205-S4617 Notebook
I need to know how to reset my acer aspire 6930 to factory settings!!!!!
A slightly different model requires pressing Alt+F10 at the start up and following the prompts. This will wipe the hard drive though, so back up everything important first. You can probably still get the data even if it doesn't boot Windows.
Mar 17, 2011 | Acer Aspire 6930-6771 Laptop
Going to reset my computer. Where can I find the reset button?
If you're trying to restore the Computer to factory settings, then you can use the VAIO Recovery Center that is shipped with the Computer.
NOTES:
  1. Click the Start button, then click Help and Support . NOTE: If the Help and Support link is not available on the Start menu, re-enable the link in the Taskbar and Start Menu Properties window.
  2. In the Windows Help and Support window, click Backup & Recovery .
  3. Under Backup & Recovery , under VAIO Recovery Center , click Launch VAIO Recovery Center .
  4. In the VAIO Recovery Center window, under Choose a program , click to select the desired option: NOTES:
    • It is strongly recommended that recovery discs be created to help restore files if the operating system will not start. Recovery discs are bootable and can be used to perform a recovery on a properly functioning hard drive.
    • The Windows Backup and Restore option opens the Backup and Restore Center provided with the Windows Vista® operating system. This provides the ability to save information from the hard drive, such as personal data files, and restore previously backed up data.
    • Computer problems related to hardware can be diagnosed using the VAIO Hardware Diagnostics option.
    • One or more drivers or factory-installed applications may be reinstalled with the Reinstall Programs or Drivers option.
    • The entire (C:) drive can be restored to its original, factory-installed condition by selecting Restore C: Drive .
    • Choosing Restore Complete System will restore the entire (C:) drive, while removing or restoring the Recovery Drive partition. Modifying the size of the hard drive partitions is also an option with this type of recovery. This option requires you to insert Recovery DVDs created using the Create Recovery Discs option.
    • To remove all data from the hard drive, including the operating system, all programs and personal data, choose the Wipe and Erase Data option. This option is provided for the convenience of advanced users who want to install a different operating system, and who want to ensure all data has been removed from the hard drive first. All other users are strongly urged to avoid selecting this option.
May 17, 2010 | Sony VAIO® VGN-CR120E PC Notebook
System is running extremely slow, when I tried to do a factory restore I get an error code 0xf00000005. I ran hardware diagnostics on the hard drive memory cpu and mobo, tests run extremely slow. I tried...
After using Darik's boot and nuke (DBAN) your hard drive will be wiped clean with little chance of recovery. This also depends on how many passes you used for the disk wipe. More passes = less chance of recovery.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process.
Jan 17, 2010 | Acer Aspire 5500 5570-2609 Laptop
Restore3
I found these instructions for you on the Sony support site.
Solution
sp.gif sp.gif IMPORTANT:
  • Before performing a recovery, go to the Sony® eSupport Web site at http://esupport.sony.com and check your model-specific support page. Look for software and driver updates or check for knowledge base solutions that may help you solve your computer's issue.
  • This model does not require Recovery CDs. Recovery data is included on a special partition of the hard drive.
  • Do not interrupt the power during the recovery process.
  • Before performing a recovery, disconnect any external devices not supplied with the computer such as printers, network cables, cameras, or external storage devices, like hard drives or flash drives.
  • Customers who purchased the Symantec® Norton Internet Security® 2007 software from the Sony Style® store with their computer must create a Norton Account to save their product key prior to a system recovery or the software cannot be reinstalled.
NOTES:
    NOTES:
    • The Windows Backup and Restore option opens the Backup and Restore Center provided with the Microsoft® Windows Vista™ operating system. This provides the ability to save information from the hard drive, such as personal data files, and restore previously backed up data.
Please update me on the same.
Regards
Sammy
Jul 10, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
