Hi, I have a Sansui high
I have a Sansui high definition set top box (STB-HD01) which is now only displaying a square on the front LCD. Initial when you turn the set top box on it will show "Hello" but then only display square on the front LCD. No other buttons (except the power on / off button) on the set top box will work once the square is displayed. There is a RS-232C port on the back of this set top box so maybe firmware could be loaded to reprogram it. Any assistance would be appreciated. Thanks Regards John (jdquee@yahoo.com)
I have same problems has any resolved this yet??
Posted on Jun 20, 2009
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
No problem - I hope!!!! Just need to know if Direct TV is compatible.
Direct TV is compatible with all TV's. Just requires the proper cable connections
Mar 10, 2011 | Televison & Video
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
Linking DVD recorder to external set top box
The TEL0713-250 records fine from my Strong settop box, but only in 576 definition Higher definition sees either nothing or black and white. Check the outpur format of your STB
Apr 06, 2009 | Televison & Video
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Okay - it is a high def 720p but you have to use the HDMI inputs for High Definition... also, using the LCD as a computer monitor the best setting is 1280 x 768 - standard p&p monitor driver for Win XP or Vista (or Win 7 Beta). The HDMI slots are on the left side and are small rectangular slots about 1" long.
Nov 28, 2008 | Sansui HDLCD3200 TV
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sansui STBHD01 Connection Issue
so do I..
i think we should just buy a new reciever...
Cheers
Trish
Mar 16, 2008 | Televison & Video
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
