Question about Nespresso D150 Espresso Machine
My nespresso D150 expels too much water through the milk steam nozzle when steaming the milk. This in turn makes the coffee drink too watery. How can I fix this?
  • 2039 Answers
SOURCE: Milk frother /steamer not working
if you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Posted on Jan 19, 2008
  • 5 Answers
SOURCE: primea ring - milk not hot
Hello!!
Okay! Looks like many of you out there has the same problem, whit the milk temerature (not me i never had).
But there is a service menu on primea touch plus series.
Im from Sweden but i will try my best to explain how to enter the menu. First of all !!MUST!! write down off parameters before changing any thing!!!! It is possible to set the grinder to grin more coffie for each cup. I think the factory setting is 85 Aroma impulse. It is possible to change that for you type of coffie beans that you use, i will diff from bean to bean.
Okay, to enter the menus you have to turn you machines off.
Now turn it on !!!!!EXACTLY!!!!! when the display lights up press your display in the following order ALWAYS IN THE CORNERS (you will not see any icons were you have to touch on you display) RIGHT LOWER CORNER, LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER.
To enter the second service menu, do as i explained before but use this "CODE" instead. LEFT UPPER CORNER, RIGHT UPPER CORNER, LEFT LOWER CORNER, RIGHT LOWER CORNER. This is it! Hope i could help you! Remeber to write down before doing any changes! DO NOT ERASE ANY FAULT CODES YOU SERVICE CENTER WILL FIND THAT INFORMATION VERY IMPORTANT!!!!!
Dont say that it didnt work, it will it´s a huge matter of timing!!!! IT WILL WORK!!!!
Let me know some results please!!
Posted on Jul 30, 2008
SOURCE: The steam wand keeps throwing out water and making my milk watery
Call the Nespresso Club, they will hepl to solve it in no time
0800 442 442
Good luck
Frog
Posted on Dec 29, 2008
SOURCE: plastic "Turbo Frother steam nozzle" blows off metal steam pipe
Pull off entire plastic wand off by unscrewing the top plastic piece. Inside the piece that connects to the screw top you should see two o-ring type spacers. The top one should be hard pastic and the one beneath should be rubber. Take the entire unit apart and clean, making sure to put all pieces back in the way they came out.
To put back on, take the top piece and put it back on the metal stem first then put the rest of the wand back on and gently push it as far up the metal stem as possible and screw back together. If you don't have the rubber spacer this could be the problem since the wand really has nothing grabbing onto the metal stem except for the rubber spacer. If this doesn't work, order another wand:
http://www.wholelattelove.com/Gaggia/gaggia_pannarello.cfm
Posted on Apr 27, 2009
reverendrave
  • 24 Answers
SOURCE: Lack of pressure from the steam wand used for frothing the milk.
Hello Juneyjune,
These coffee systems have a series of small rubber 'O' rings that tend to crack from condensation over time causing your low pressure problem.
The 'O' rings are connected to a heater that looks like a horse shoe mounted in back of the grinding unit.
I would recommend contacting Miele technical services. They can have a technician come out to replace the 'O' rings or you can order them from the technical services rep if you know someone that can replace them for you. Just be careful. These machines operate off of 220 volts and that is no fun to get shocked by. I have been many times with this machine
Good luck!!!
Posted on Sep 15, 2009
Coffee machine steam wand pressure issue
Good question. I have been surprised before today after checking the manual for various gadgets. There are thousands of manuals online which can be searched for if it is missing. We have a bench top water filter fitted. When you have one of those, the difference is so noticeable that you will only want drinking water from there
Feb 28, 2014 | Coffee Makers & Espresso Machines
It shoots too much water coffee come out watery
try adding more coffee to the filter, or making the grind FINER or both
Mar 08, 2011 | Coffee Makers & Espresso Machines
Window shows "Expel Air" message.
Fill the water tank.
- Turn the program selector to "On with
light" and place containers below the
hot water dispenser and the steam
nozzle.
- Press the hot water button, turn the
steam selector counterclockwise
and let water run out until it streams
steadily.
- Press the hot water button again.
Turn the steam selector to "o" to shut
off the water.
ENJOY YOUR COFFEE
Jan 15, 2011 | Miele Coffee System
My steam function more water than steam comes out. Yhe thermostat is turning on and off but when you open the steam valve you end up with more water than steam??? To froth the milk i have to do 4...
Replace the thermostat for the steamvalve, it is not keeping the element on long enough or you need to descale boiler because there is not enough room for water.
Jan 30, 2010 | Gaggia Classic Espresso Machine
Water Leaks from the head gasket while heating up to use steam
This is a result of the water temperature in the boiler increasing, thereby expelling water that may remain in the lines out of their respective exit points. A solution may be to place a container under the group head to catch the water, or opening the steam valve partially to allow the water to exit through the steam wand (again placing a vessel/cup/pitcher there to catch the water). This is a problem that even higher end (dual-boiler) models have, due to the necessary purging of water that accumulates in the steam wand during down-time.
Don't look at it as a problem, but simply as a quirk that single-boiler machines have. If you are still irked by the issue, consider buying an inexpensive manual frother (Bodum makes these) to froth and heat your milk (in the microwave after frothing) separately. An added plus is that you can do this while you make your espresso, so if you make primarily milk-based drinks (latte, capps etc.) you'll save on time.
Dec 21, 2009 | Saeco Starbucks Sirena Espresso Machine
How strong should the output for the cappucino/ latte steamer? Mine just sort of dribbles the steamed milk. Thanks
When steaming the milk/cream make sure to hold the rubber nozzle to the very bottom of the cup and also make sure you are leaving enough water to produce the steam after brewing a cup of espresso. Also you'll want to check the breather tube that sticks up from the nozzle and make sure it is free of buildup.When the steamer is operating correctly it should produce a loud growling sound.
Nov 06, 2009 | Nespresso D290 Espresso Machine
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
0800 442 442
Good luck
Frog
Dec 28, 2008 | Nespresso D300 Espresso Machine
Steam wand shooting water instead of steam
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
Nespresso D150 Espresso Machine Logo
123 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
