Question about Acer Aspire™ T180 PC Desktop
Printer port Can you tell me what the parrell port for the printer d25 pin is called under the settings menu lport 1,2 or 3 as i am having trouble getting the printer to work
  • Acer Master
  • 4,737 Answers
It's called the LPT1, LPT2 and LPT3. You can select the LTP1 to install a printer if you are using only one printer. Good luck
Posted on May 05, 2010
Kids gave me a printer/scanner Epson model number c171a. Need the cable to it. AN oldie but looks like a pretty nice printer. Can you help??
The cable you need depends on the unit. I am not aware of a C171a model from Epson. I have seen it listed as a version of the RX500. In that case you need a USB cable with A/B male ends.
Otherwise, most printers (from about 1997 on) will use a USB cable. This has two male ends - a square end goes into the printer and a rectangular end that goes to the computer (called A/B). For older printers (there may be multiple ports or just one), you may see a parallel port (the cable has a wide rectangular plug on both sides with 36 pins) or serial port (the cable may have DB9 (9 pin), DB25 (25 pin) or both). Often it is called a RS-232 port. For a parallel port connection, you would need one that is designed for scanners and bi-directional communication (USB to parallel adapters are available to connect this to a new computer but you still need the bi-directional version). Similarly, USB to serial adapters are available.
Generally you can tell what cable you need by looking at the back of the unit where the ports are. (Although some all-in ones have the USB cables in other places - routed through the side of the unit but the plug is near where the ink cartridges go.) Then the size and pin counts for parallel or serial tell you what cable to get. There is usually a symbol indicating the cable type as well near each port. USB cables are usually indicated by a tree like symbol with curved branches.
I hope this helps.
Jul 25, 2010 | Epson Office Equipment & Supplies
Casio QT-600 Printer connection
You have to use serial communication cable If you have purchased this cable from market,it will not work.I tell you how you can make it yourself.
QT side 9pin femateConn.......Receipt Printer side 25 pin mate con
Pin 1-----------------------------------NC
Pin 2-------------------------------- 3
Pin 3-------------------------------- 4
Pin 4------------------------------- 7
Pin 5------------------------------ 8
Pin 6------------------------------ 20
Pins 7,8,9------------------- NC
After connecting with com.Port 4 initilize the QT.It should
deduct the printer. If no change the printer
Apr 17, 2010 | Casio QT 6000 Point of Sale Terminal
BJC 80 w/ Vista OS prints 1/2 page and goes to error mode.
Purchase a PCMCIA parallel port card. That's a PC Card parallel port adapter. It provides a native parallel port to laptops that do not have one built in. Works perfectly in ALL cases, even with the scanner cartridge.
Jun 09, 2009 | Canon BJC 80 InkJet Printer
How do yor connect a printer with a parrel cable to a computer without a printer port
There are many parallel port add-on cards available on the market. Ask your local computer dealer for a "PCI parallel port add-on card".
This card slots into an empty PCI slot in your computer.
Regards,
Graemevm
Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
Setting bluetooth on a Epson stylus SX600FW
the bluetooth dongle for your printer is sold separately. call epson store to get one.
Jan 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Having troubles with fax not dialing out
Disable call waiting is only set to "yes" if you have call waiting, press "menu" then scroll down to "reset all setting" make sure to backup phone entries before doing this . Follow the "fax settings" below:
FAX SETTING FOR 5500 (VOICE MAIL)
- ANS. MODE TO "YES"
- ANS. MACHINE RINGS "3"
- FAX RINGS TO ANS. "4"
FAX SETTING FOR 5500 (ANSWERING MACHINE)
- ANS. MACHINE RINGS "4"
- FAX RINGS TO ANS. "3"
Nov 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
My rather old parrell port scanner ids not found by my pc
Greetings,
what's your PC and OS and the printer ?
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | Office Equipment & Supplies
Acer Aspire™ T180 PC Desktop Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
