Question about Bose Televison & Video
How can I open a Bose remote contraol. I have remove the only screw I see but it's pretty hard to pop. Any suggestions?
    Problem Solver:
  • 12 Answers
Once screw is removed, pry the bottom gently with a screwdriver. Now apply lateral pressure between to 2 halves, push to the side. there are 3 pressure points on both sides that need to be released. Once open, you'll see a black diode at the top with a copper wire wound around it. Chances are, one side has separated from the board and needs to be re-soldered.
Posted on Feb 28, 2011
How to remove the back cover to change a dead battery?
most cases are held together by screws, so screws maybe hidden behind the labels, manufactures information, and felt material,
and cases may also be a snap together type, you will have to force an opening slide the screw driver around the case while pyre bar type action pop the case open.
www.ask.com/mfg.name/make/model/disassembly/case/
www.ask.com/mfg.name/make/model/procedures/replacing/internal/battery/instructions/
www.youtube.com/mfg.name/make/how/to/replace/internal/battery/
this is a video on how to do it
you mite just :type of equipment/battery/replacement/
Oct 22, 2015 | Apple Bose SoundDock Series II Digital...
Bose wave operate without remote control
if there is no hard wired on/off button on that radio you WON'T be able to turn it on..only thing left to do now is to pay bose all of the money they ripp people off and splurge for a factory remote..that's a rip off but I'm not surprised bose company has devolved into little more than a over charging pusher of mediocre goods..sorry you got screwed. repeat after me..no more bose they are a rip off repeat till you lose that silly urge to waste cash on chinese goods repackaged as high end audio..
Dec 01, 2013 | Audio Players & Recorders
Our bose remote stopped working after a fall from a table
hey....normally with remotes there are only so many things that can go wrong....normally when it is dropped either the battery terminals can short each other out..or the IR LED breaks off the PCB or you get a dry joint somewhere i would suggest that you pull it apart...do this by using a small flat bladed screwdriver and gently pri the case apart remebering to remove any screws that it might have on the back panel and just inspect for any of the faults listed above its normally nothing a soldering iron and some solder will fix...if it has sustained quite a hard fall (and i mean really hard) the pcb can sometimes break straight across it and then the remote is useless but it is worth opening up and having a look first hope this helps,ben
Jan 09, 2010 | Bose Cinemate Digital Home Theater System...
My Bose lifesystem 48 will not start when i start it up error 802 is showing in the display. I can her some nois (tikking) from the harddisk. i am from Norway but my Bose is from USA .I use a transformer...
Purchase a new bose mk4025gas hard drive from impact computers .com for 100 bucks and install, a monkey can take six scews out, pull back up and slide off top remove hard drive from the side of the dvd player, just pull out remove 2 screws from bottom and then pull off ribbon. install back in reverse order.
Dec 22, 2009 | Bose Lifestyle 48 System
How do I pry open my Bose Wave Radio cover to change the fuse located inside. Even after opening the screws the casing does not come out!
ON THE WAVE THERE IS OUTER SCREWS AND THEN UNDER THE FRONT LOWER LIP YOU NEED TO GENTLY SEPERATE THE GRILL SECTION FROM THE BASE BY INSERTING TWO FLAT BLADE SCREWDRIVERS 2 INCHES IN FROM EACH SIDE AND SLOWLY LIFT UP AND FOWARD IT WILL POP OFF RATAINER CLIPS HIDDEN ON LOWER FRAME.
Nov 04, 2009 | Bose Wave Radio
Bose Remote not linking to Samsung HDTV
I got my bose remote to work when I did a system update on the remote. Turn the TV on. Select the TV video input that connects the system. On the control console, press and hold setup until the system information screen displays. line 5 will display the currently installed console software version. on the remote press any button. Line 10 will display the currently installed remote software version. Do a bose system update. On the control console press setup. on the remote control, press the down arrow until update is highlighted and press ok. make sure yes is highlighed and press ok. on the control console plug a clean usb drive into the usb port.when prompted, remove the usb drive and connect it to a computer. open the drive and double click on the download_launcher file, which should bring you to an update page on bose.com. Once complete, put it back in the control console. When the update is complete remove the usb.
Feb 22, 2009 | Bose RC-28S stereo expansion kit - White...
Can't remove battery of remote to bose radio/cd player (won't work)
On the back of the remote there is a small hole. You need to slide the small lock in the hole over and the battery compartment should pop open. This requires something small like a straightened paper clip. You may need to coax it a little with your finger by pushing out off the end of the remote. There is a picture of this on the back of my remote. I just removed my battery so i could replace it. The battery size is CR2032.
Oct 08, 2008 | Bose Wave radio remote control - Graphite...
How can I replace the fuser on xerox xc865
it is pretty easy. You have to remove the lower front cover, located just above the paper tray, 2 screws to remove and pull forward.
Then there is one screw in the front of the fuser, It is a shoulder screw. Once that screw is removed you push the upper fuser toward the back of the machine slightly. It will pop off a locating pin. There are 2 plugs to disconnect and the fuser will come out once those are unplugged. The pressure and pressure cleaning roll just pop out of the frame once the upper fuser is removed.
Not hard at all.
Sep 07, 2008 | Xerox Office Equipment & Supplies
Opening external drive case
Actual solution. The darker side panels pop off and they alone hold things together. Simply pry each side away at rear. That would be end with power and USB connections are.
Dec 10, 2007 | Maxtor Personal Storage 3000LS (G01J060)...
Home Audio Bose 48 - Remote not working
Had an issue with the Bose Remote RC38t1-27 not working at all. Changes batteries twice to no avail. Called Bose Tech support who walked me through the fix. I unplugged the power cord connected in the back of the system. Waited for 30 seconds or so and plugged it back into the system. Also made sure the power cord was uncoiled/unbundled as the RF (Radio Frequency) signal is within. Bingo!
Aug 05, 2007 | Bose Lifestyle 48 System
Televison & Video Logo
555 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
