Question about Toshiba e-Studio 35 Copier
My Toshiba e-Studio 35 Copier keeps saying it needs toner, even though I have put in new toner. I must be doing something wrong. Just don't know what. I shook it to redistribute the toner (as directed); I removed the tape ( as directed); put it in arrow up. I twisted the new cartridge into place. I have tried a number of configurations, with the arrow up, with it down. The instructions aren't clear.
  • 34 Answers
Generally it takes a while to add toner if you didn't change it when it asked you to. Check your user manual or go online to Toshiba's website and download another one.
Posted on Apr 30, 2010
Where do i find the toshiba 181 toner sensor
How to clear toner empty message
All The Toshiba Estudio And Toner Cheap Continually Working / Without Change Cheap only buy a toner bag open right side of toner and refill : if you don't put the toner your machine , its working because huge toner already have with developer's / have a code Like 08 ***! but We are technician can't say internet if you call land phone my number 8801741630080 help 100%
Dec 06, 2014 | Toshiba e-Studio 181 Digital Copier
Toshiba e-studio 5520c cd81 keeps coming .even after cleaning the toner disposal bottle
This error code is not for the waste toner box. The problem is the transfer waste motor (right side duplex door of machine). Probably clogged auger stalling motor which needs to be vacummed out.
Aug 03, 2014 | Toshiba e-studio 5520c Digital Copier
How removed toner indication still toshiba copier e-studio-181?
toshiba e-studio 181 toner indication patmanent still.
Feb 26, 2012 | Office Equipment & Supplies
I dispose of toner and still keep getting messages
I assume when you say you dispose of toner you are emptying out the waste toner bottle and putting it back in the machine. if so here's your problem.
There is a sensor, mounted to the copier, just behind the waste toner bottle (on the upper righthand side). This sensor shoots a beam of light through a small portion of the waste bottle - if the beam is not received on the other side then the copier thinks the waste bottle is full. NOW...even if you have emptied it the interior of the bottle may still be dirty/black enough (leftover residue) to stop the beam from making it through the bottle - this gives you the message. You will need to put in a new bottle.
Jan 23, 2010 | Toshiba e-Studio 350 Copier
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
Keeps on coming up with install new toner
The toner detection sensor in the toner hopper is either fouled or defective. This is why that no matter what you've done thusfar, it's still saying it needs new toner. Not an easy repair. Recommend a certified Toshiba tech to do the work.
Aug 28, 2009 | Toshiba e-Studio 232 Black and White...
Toshiba E-Studio 35 PM Kit Instructions
open front door and remove waste toner container, unplug connector and loose blue screw slide out developer unit removed top cover empty developer(100%). then open by-pass, duplex and jam access cover , remove two screws and slide out drum unit .remove charge corona. release latch on rearand remove bracket/bar( on top of drum),turn level counter clockwiseto release slide drum shaft out.remove two screw lift drum blade before install new drum & blade needdust some lubrication powder.after put everything back,hold down05 while turn onthen enter200,press start,let run about 3 minutes ,the value should bebetween 2.35-2.45 press set or interupt key same procedure doing 08then401 set to 0
Dec 15, 2008 | Toshiba e-Studio 35 Copier
Toshiba e-Studio 25 and Windows XP
your computer connect to Copier thourgh USB cable port or parellal port .select first communication port.and install software.
Jul 24, 2008 | Toshiba e-Studio 232 Black and White...
172 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
