Question about Brother IntelliFAX 4100 Laser Fax
THE FAX MACHINE HAS WHITE OUT ON THE LENS-HOW
THE FAX MACHINE HAS WHITE OUT ON THE LENS-HOW DO WE CLEAN AND WITH WHAT CHEMICAL?
  • 34 Answers
For ink on the glass use glass cleaner with ammonia, for whiteout, use isopropyl alcohol on a cloth. be gentle.
Posted on Apr 30, 2010
How can I clean the lens of my tele-fax machine
Hi..
Use a soft cloth moistened with a little water on the cloth, then rub on the glass lens on your fax machine.
TQ
Sep 16, 2011 | Sharp UX 108 Roll paper Thermal Fax
Black line on scanned copy
If you notice poor image quality in scans, faxes, or copies, you may need to clean the scan lens and the white roller.
  1. Unplug the power cord from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One. Note: The scan lens is located under the white roller.
  4. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  5. Reinstall the white roller.
Jul 26, 2011 | Lexmark X4270 All-in-One Multifunction...
I have a X4270 fax machine. Whenever i send a fax the recipient says there is a black line running down the left side of the page. I changed ink cartridges but it did not help. Can it be fixed?
The X4270 has a pretty straightforward scan path. If you follow the instuctions on this link, you'll find that you can clean the white roller and scan lens with a lint free cloth and water. It will get rid of the mark....unless you've managed to do something ugly like run a staple through the machine (I did that on a laser and scored the drum....that sucked).
Carl
http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.htmlhttp://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html
Feb 18, 2011 | Lexmark Office Equipment & Supplies
1120l Ricoh Fax Machine which can receive a perfect fax but when sending a fax the receipt part which shows a reduced page of the fax sent is completely grey and the fax received at the other end is also...
If it can receive a perfect fax but the problem is only with the image it scans, then the problem lies with the optical portion of the fax machine. Try cleaning the glass where the fax machine scans your original -- it may just be dirty or there may be some white-out stuck to it.
To clean it, just use a damp lint-free cloth and wipe it down, then dry it and try faxing again. If the problem doesn't change then the issue is underneath the glass -- the scanner's lens or mirror may be dirty.
Jul 06, 2010 | Office Equipment & Supplies
When making a copy on the fax machine, it has a la...
your must clean scan unit ,mirrors and check drum .make a white copy if the problem occurs change drum unit
May 20, 2010 | Brother IntelliFAX 4100 Laser Fax
Lexmark x4270 fax machine receives faxes but won't feed paper
Try cleaning the rollers in X4270 printer. You may need to clean the scan lens and the white roller.
1. Unplug the power cord and the phone line from the wall.
2. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
3. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
4. Reinstall the white roller.
5. Reconnect the power cord and the phone line.
Next, try to make a standalone copy and let us know the results.
Apr 15, 2009 | Lexmark X4270 All-In-One InkJet Printer
Continually getting paper jams. Not picking up the paper. probably needs cleaning and maintenace. Bought at staples a couple of years ago. Where can I get service. Model is Intellifax 4750
Have you tried to clean the feed rollers yourself?
I would try cleaning the feed rollers before bringing it in for service.
You can slide the paper drawer completely out, and then look under the machine to find the feed rollers.
Usually they are Gray.
There is a chemical that you can buy at your local hardware store called "Goo Gone". This is a cleaning chemical that will clean the rollers and not dry out the rollers like alcohol would.
I hope this helps.
Good luck.
Mac =)
Feel free to ask more questions if you have any.
Mar 21, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax machine brother 885mc
1- did you check the glass?
2- There is also a white metal plate opposite of the glass, if it has a black dot or is dirty it will give you black lines.
Dec 05, 2007 | Office Equipment & Supplies
Brother IntelliFAX 4100 Laser Fax Logo
35 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
