Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Our Bosch is 3 years old. I always use the Quick
Our Bosch is 3 years old. I always use the Quick Wash cycle(39-40 minutes) & get excellent results . Now however, it stays at 1 minute for 8-10 minutes & then restarts the same cycle. At 1 minute, I opened it, & it was full of suds & water & the water was just lukewarm. Usually it is hot & steamy. I turned up our water heater, tried Bosch again but still got the same results. Do you have any idea of the problem? Thank You, Mary
  • Bosch Master
  • 2,605 Answers
Hi, What you're seeing when it display's the "1" is actually an error indicating a fault with the heater circuit. Likely if you select just a rinse cycle it will complete fine since the rinse cycle doesn't call for heat from the element/control. sooo... Based on your description I'd say the issue is with the control. Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described. ( unless you requested a resolder option...see below re: my opinion on this ) I digress, As I've alluded to the issue is within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). My first suggestion would be calling in an authorized bosch servicer if that is an option for you and your budget however, If you cannot afford that option or feel capable of checking this on your own, there`s a way to visually inspect the control yourself. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever to finish and eventually display's the "1" error because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed. **My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...half assed will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.** Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness. Good luck. macmarkus :)
Posted on May 01, 2010
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
Bosch dishwasher actual runtime versus indicated runtime.
The usual discrepancies with run times is due to water heating time.
For example, your dishwasher may be estimating run time + time to heat the water from cold.
If your dishwasher is connected to hot water instead of cold, it will skip the majority of the heat cycle and adjust the time accordingly.
On the other hand for other people, their dishwasher brands may say "50 minute wash" but this does not take into account heating time, so wash can be anything up to around 70-80 minutes.
Jun 01, 2013 | Dishwashers
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Cycle time
yes its normal.bosch dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Reset model smu7052uc
there is none- if the program is mucked up-- pull the plug for 5 minutes
Jul 16, 2009 | Bosch 24 in. SMU70 Built-in Dishwasher
Bosch Exxcel Type S9N61B
IF YOUR DISHWASHER IS OVER 3 YEARS OLD IT HAS PROBABLY BLOWN THE HEATER IF THEY ARE USED ON REPEATEDLY LOW TEMP WASHES FAT CAN BUILD UP AND DESTROY THE ELEMENT ON A 35 QUICK WASH IT SHOULD HEAT UP WITHIN 12 MINS OF STARTING IF NOT HEATING APPLIANCE WILL WASH FOR UP TO 3 HOURS IN COLD WATER IF CYCLE TIMES ARE NORMAL BUT NO HEAT IS EITHER A THERMOSTAT OR PCB FAULT THE FORMER IS LESS LIKELY,YOU SHOULD GET AREADING OF AROUND 25 TO 30 OHMS ACROSS LIVE AND NEUTRAL AND INFINITY ACROSS LIVE TO EARTH AND NEUTRAL TO EARTH.
HOPE THIS HELPS
Jul 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Excell Dishwasher
drain pump is running all time. cause is a leak. remove bottom front panel and mop out water or can also tilt at 45deg and water shud run out. machine shud then run but you then hav to find leak
Mar 04, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
228 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
