Question about HP Pavilion F1703 17" LCD Monitor
How do i change the resolution of the monitor outside of the operating system? the computer i am trying to hook it up to needs 1280x1024 and the monitor for some reason is running at 640x640
  • 186 Answers
Display on control panel will fix it ok;
Posted on May 01, 2010
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
After installing the ASUS EAH5450 my computer turns on and runs fine on my desktop monitor. However, I've hooked up a HDMI cable to my Sharp Aquos and the tv says it's receiving an incompatible...
The easiest thing to try is change the screen resolution before connecting via HDMI. The process is a little different depending on what operating system you're using.
For Windows Vista/Windows 7: 1. Right click on your desktop and select "Screen Resolution" 2. Slide the bar to change the resolution to either 1024x768 or 1280x1024. 3. Click apply.
For Windows XP: 1. Right click on your desktop and select "Properties" 2. Click on the tab to the far right that says "Settings" 3. Under Screen Resolution, slide the bar to change the resolution to either 1024x768 or 1280x1024. 4. Click apply.
Either of these resolutions should at least give you picture when you reconnect with HDMI. Once you get a picture, repeat these steps and gradually move the slider higher to get a better resolution picture. If you receive the incompatible signal message again, just wait 15 seconds and the previous setting will be restored.
If this doesn't work, you may also have to adjust the screen refresh rate. From the same window that has the screen resolution adjustment bar, click the link or button that says "Advanced." The second tab, "Monitor," has a drop-down menu to adjust the screen refresh rate. Depending on your HDTV, the most common setting for this could be 60 Hz, 70 Hz, or 120 Hz. If none of those values work for you, you should check the manual that came with your TV to check what the proper resolution and refresh rate should be for your computer connection.
Jun 10, 2011 | ASUS EAH5450 SILENTDI1GD2 graphics adapter...
I get (D-sub out of range 53.6 k hz / 85 h z) how do I fix this?
this is a how to video on how to fix the video out of range error.
Mar 05, 2011 | LG 22" FLATRON LCD Monitor
My computer is on but all I see on the monitor is a floating box with the message "Not Optimum Mode Recommended Mode: 1280X1024 60Hz.
Try connect a different monitor on your computer and change the resolution to 1280x1024. After that, replug the new monitor and it should work.
Feb 28, 2011 | Samsung Computers & Internet
Hello I can't get anything on my screen except
Your PC is putting too high resolution for he VL1918 to display.
You need to set your PC video out put to the native resolution of the VL1918, which is 1280x1024 @60Hz.
You will have to hook up your old monitor (crt type?) and set the new resolution.
Or boot up in safe mode (hit f8 during boot up), and set the resolution to 640 x 480, reboot into regular mode, then rest the resolution to 1280x1024 260Hz.
Also watch out for bad caps in this monitor: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Apr 07, 2010 | Princeton Digital VL1918 Monitor
When booting up my windows is loading and then my screen goes black and come up with an error: recomended resolution is 1280x1024... how do I fix this?
Most probably your computer has a higher resolution or refresh frequencies set in Desktop Settings than supported by the monitor. It might be also, that you have previously installed a monitor driver for a different monitor model, and the computer is using resolutions and frequencies supported by that previous monitor, with which your new one can't cope.
The solution would be to boot the computer in safe mode (hit F8 key when the computer is starting, you can hit it a couple of times, until you see a menu; choose "Safe Mode" and hit Enter).
Go to Desktop Properties, change to Settings tab, and click "Advanced" button. In the new window choose "Monitor" tab and change the monitor to "Plug and Play monitor". Click OK to accept the settings and close both windows.
Now reboot the computer - it should start with a rather low resolution, but the picture should be visible. Now you have to go to your Desktop Settings again, Advanced tab, and move the resolution slider to position 1280x1024. Accept and enjoy.
If the computer still doesn't boot, go to safe mode again, go to Control Panel, System, Hardware, Device Manager, drill down to Monitors, and delete all the monitor devices installed. After a reboot, system should start up and find new hardware, and install Plug and Play monitor. Set the optimum resolution of 1280x1024 as written before.
Nov 18, 2009 | Samsung SyncMaster 710VT TFT LCD Monitor
I just bought a new monitor, Acer 22'' & I see it says my computer graphics card needs to support 1680 X 1050. So I checked and my system only goes up to 1280 X 1024. Will my new monitor work well, or...
it will work but the resolution will be off and you wont get the best quality since the screen is bigger than the video card can handle.. i would get a new video card that would provide enough resolution to get the best results from your monitor.. i had to upgrade when i hooked my computer up to a 32" tv
Aug 03, 2009 | Acer V223WBD Monitor
Error message on new monitor
I don't know for sure because I don't own nor have I ever used one of these monitors before but this error likely means that either that there is a problem with the resolution or the frequency coming from the video card on your computer. The recommended resolution is 1280x1024@60Hz.
You can hook your PC up to your old monitor and check the Display Settings. According to the manual for the LG1780U (and many others) 640x480, 800x600, 1024x768 and 1280x1024 should all be acceptable values, although 1280X1024 will give you she sharpest image for this monitor.
If you still need help LG offers 24/7 tech support @ 1-800-243-0000.
I hope this helps!
Jan 01, 2009 | Computers & Internet
I have an error message on my screen which ios moving around. It says - 'not optimum mode. Recommended mode : 1280 x1024 60Hz'.
Sounds like you have an LCD monitor. LCD monitors look best in their native resolution. Yours must be 1280x1024. You need to (assuming this is a Windows PC) right click on the desktop and choose Personalize, Display Settings (Vista) or Properties, Settings (XP or older). Set the slider to 1280x1024. It'll confirm the change and then the message should never reappear.
Aug 28, 2008 | Computers & Internet
HP Pavilion F1703 17" LCD Monitor Logo
56 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
