Question about JVC KV-MRD900 Car Video Player
My daughter put a sticky DVD in player and now it will not read dvd? What can I do?
  • 11,896 Answers
Remove it, clean the disc with rubbing alcohol and a cotton swab in a circular pattern, let it dry and then you'll be good to go.
Posted on Apr 30, 2010
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
Every DVD I put in the DVD player says disc error. Why is that
good day
the cause is either the disc motor not rotating or the laser sensor is dirty. try to clean first the laser with soft fiber cloth apply gently sometimes due to sticky in some part. just let me know if it works or still doesn't read so i can give further solution.
Mar 22, 2012 | Televison & Video
My daughter's portable DVD player says no disc
You need to clean the lens - use a can of compressed air and a q-tip. Rub gently, the suspension of the lens is very sensible and can be easily damaged beyond repair.
Aug 29, 2011 | Philips DCP85037 85 in Portable DVD Player
I put DVD in player. It will spin but won't read DVD. Then it will say, no DVD! It has not been used much. What do I need to do?
Dear mgunwall, If dust particles are sticking to the DVD surface, use a piece of soft cloth to wipe off the dust. To hold the DVD, insert a finger or thumb inside the center hole of the DVD or handle it by the edges but never touch the shiny surface. If the DVD surface feels sticky or greasy, mix some baby shampoo in lukewarm water and use cotton or soft cloth to gently rub the DVD surface with this solution. Make sure the DVD is completely dry (no water drops) before putting it back in the player. If you notice a scratch on the surface of a CD or DVD, I would suggest that you immediately make a copy of the disc (if it's not copyrighted). If none of the above work, try cleaning the lens of the DVD player by using a CD laser lens clear CD like this: http://www.comparestoreprices.co.uk/images/ha/hama-cd-and-dvd-laser-lens-cleaning-disc--ref-11434.jpg
Mar 01, 2011 | Sanyo DWM400 DVD Player
Reads, NO DISK
Curtis DVD player does not supports the file type.
May 28, 2010 | Curtis DVD1045 DVD Player
My daughters GoVideo DVD player always says CHECK DISC!
If no disk is detected it means that the lens are dirty or defective.
If the lens cleaner disk, or using Qtips and alcohol did not work, then the lens pickup or the disk drive must be replaced. this involves precision soldering and must be done by a technician. Regards.
Jul 04, 2009 | GoVideo Televison & Video
When I put my daughter's Leap Frog brand DVD into our Phillips DVP392 player, it asks for a password. It doesn't do this for any other DVD. Ideas?
i think you should ask your daughter if she put passwords to lock the DVD.if not then its compatibility issue.i mean its not compatible or manufacturer encoded passwords to avoid piracy.
May 16, 2009 | Philips DVP3982 DVD Player
Duraband portable dvd player
try to clean the optic lense with a q-tip and some rubbing alcohol that should work if not i think you are in for a new dvd player i hope this is helpful to you
Mar 07, 2009 | Televison & Video
Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Jan 27, 2008 | Lite On LVW-5115GHC+ DVD Recorder
JVC KV-MRD900 Car Video Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
