Question about Stoves 600SiDOm Gas Kitchen Range
Stoves Q600 single oven heats up but green light starts flashing and oven heat cuts off. Have to switch off at mains for it to respond again. any ideas what teh problem is?
    President:
  • 2,468 Answers
The oven thermocouple is sending the E.C.U. a reading that its ready(as in hot enough) but in reality it isn't,then the flashing green light on the board knows the parameters and they are not met,replace the oven thermocouple and first try this,then if not the E.C.U. could have cold-solder joints on the board or bad signal wires called ribbon cables between the board and any sensors,check all wiring especially small ribbon signal pick-up cables,they do get hot and deteriorate too
Posted on Apr 30, 2010
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Aug 02, 2011 | Stoves 720EF Electric Double Oven
Hi, my Stoves 720EF is 16 years old. We have had no problems until today when we noticed that the main oven was not heating up. The light and fan come on, but no heat. The timer is not set. We have...
Peter
ISOLATE MAINS POWER BEFORE WORKING ON ANY APPLIANCE
It sound like an element problem, but, you need to investigate, before we can go ahead to define the exact problem, the varistate control is working because the fan operates.
Remove the ovens, remove the rear and may have to remove the top, or sides, remove the bottm fan, you should be able to vue the element, look for Black Grey burnt blow out, not carbon or food spots, if you see or feel a rough spot on the element, it probabily is blown. Replace heating element. Seach in whitegoods.co.uk for part, you will need model and serial numbers.
Hope this has been helpful
John
May 17, 2011 | Stoves 720EF Electric Double Oven
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
Gas oven will not heat.
The main thing that goes out is the ignitor on these stoves. If it appears to be glowing it does not mean a thing. The ignitor gets weak. It should be very bright. if it is a dim orange it is bad.
Apr 12, 2009 | Magic Chef 9122 Gas Single Oven
Oven comes on of it's own accord following power failure
no you are not over reacting that could have burnt your house down I would demand a new one sometimes you just got to be pure hateful with these manufacturers and tell them you going to give bad ratings all over the net hope you get somewhere with them Please give high rating
Jan 05, 2009 | Ovens
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Mar 01, 2008 | Electrolux EOB5630 Ultrafan Electric...
Stoves 600SiDOm Gas Kitchen Range Logo
144 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
