Question about Sony PFM-42V1 42 in. HD-Ready Plasma Television
Can someone help with the name/product code number of the cable that plugs into the TV off the receiver box? Thanks.
  • 153 Answers
1) "Composite Video" cable yellow
and two red and white audio cable should 100% work
if you have a Video out/in jack on tv and reciver
100% it will be there.
and it will work
just you need to ask for "Video in" (also called composite video cable) cable with both side yellow jack
regards
Posted on Apr 30, 2010
I have a 32 inch ILo television and I am trying to program a RCA universal remote for it. I have the codes for the remote but can't seem to find instructions for how to program it. Could someone p
1. Find codes for each device and brand on
page numbers shown below.
2. Press and hold the TV, VCR1, VCR2•LD,
SAT•CABLE, or AUDIO button you want to
set up.
3. Enter the three digit code from the
TV, VCR, Laserdisc Player, Satellite Receiver,
Cable Box, or Audio code list.
Device Page
TV 11
VCR 12
LaserDisc Player 13
Satellite Receiver 13
Cable Box 13
Audio Equipment 14
4. Release the device key.
5. With the device on, press another button, for
example CHANNEL UP. If the device
responds, no further programming is
required. If the device does not respond,
repeat 2-4 using another code.
Aug 04, 2012 | iLO 3200 32 in. LCD Television
Setting up my rx v2400 to my tv
The setup may depend on your TV and other components and how you plan to use the system. Does your TV have analog or digital audio outputs? The receiver has analog and both types of digital inputs (coaxial and optical).
Use the best cables that you can. You can get all cables at online cable stores for much less than at the electronics big box stores. I'll assume that you already have the speakers connected to the receiver.
Next you can either connect your devices (cable box, blue-ray player) the receiver's inputs. Then connect the receiver's video out to the TV. This is great if you will only listen to the devices with the home theater system. Then you can also connect the TV audio out to the receiver for the OTA TV audio. For this you probably need component video cables and audio cables. These are all cables with RCA plugs.. Then get another audio cable for the analog or digital optical output of your TV. For some TVs the only audio out is the headphone jack. In that case, you also need a 3.5 mm to RCA adapter (the simplest is 3.5 mm M to RCA F/F for connecting to an RCA audio cable). For this method, you won't have to turn off the TV speakers most of the time; the TV won't have any audio.
Alternatively, connect each device audio/video out to the TV's input and then only connect the TV's audio out to the receiver DTV audio IN. Since the receiver doesn't have HDMI, this is the best option if your devices have HDMI out. For this, use the appropriate number of HDMI cables and the analog or digital optical audio cable from the TV to the receiver. Then turn off the TV speakers and enable the external speakers in the TV menu. You can connect to any of the receiver's inputs. If you use the labels, you'll find it easier to turn on the inputs.
If you have any devices with composite video output, use the same basic steps as for the component
The documentation for the RX-V2400 is available at the Yamaha product site: http://usa.yamaha.com/en/products/audio-visual/hifi-components/stereo-receivers/rx-v2400_black__u/?mode=model . You'll need to be a registered Yamaha user (Easy-Pass) to read the manual online.
I hope this helps. Please add a comment with your devices (including the model of the TV) for more specific information.
Feb 19, 2012 | Yamaha RX-V2400 Receiver
I have a VW37L Vizio connected to Dish satellite, I suddenly have no sound.
Hello, my name is Cheri Torres and I am with the DISH Network Internet Response Team. I came across your post and wanted to help. There are a few things that you can try in order to get the sound back on your TV. The first step to try is a hard reset, you can do this by unplugging the receiver from the wall outlet for 10 seconds then plugging it back in. If this does not fix the issue you are going to want to check your cables. Make sure that the cable running from your TV into the DISH Network receiver box is not damaged and make sure that it is plugged in securely. You can also try unplugging the cable from the DISH receiver and TV and then reentering it. The next step to try is using the same cable on a different device such as a DVD player, gaming system etc. If the cable does work on a different device the issue is probably with your DISH receiver box. If the cable does not work with another device you are going to want to try replacing the cable itself. I hope you find this information useful and if you have anything further questions please feel free to ask. Thanks and have a great day!
Oct 30, 2011 | Vizio VW37L 37 in. LCD HDTV
I have a Denon AVR-3803 receiver and I have a DirecTV HD DVR HR 20-700. We believed someone hit a button on the receiver to cause the screen to go black. What buttons should we be pressing to try and...
First thing would be to check all the input settings on the TV and Receiver. Without knowing how it's connected, follow the cables from the Direct TV receiver to the AV receiver then to the TV and note the location. (input name) on the electronics back panel. Then make sure the TV is on that input, (Video1, Video 2, etc) Same on the AV Receiver, make sure the name on the back of the unit where the video cable is plugged into is displayed on the front of the Receivers display (CBL/SAT, HDTV, etc.) Lastly, make sure all the products are "on" especially the Direct TV receiver. It happens! Hope this helps. If you still have an issue, post a comment/reply and I can help you further diagnose the problem.
Jun 01, 2011 | Denon AVR-3803 Receiver
Please someone help me! Serial number:1045 - 1721 - 9514 - 3302 - 2490 - 1529 Activation number:2437 - 3316 - 5390 - 4716 - 4533 - 5716 - 3487 Activation Type:Normal what is authorization code? write me on...
Hi AVRIL:
Auth Code: 5985 1681 9760 3697 1285 5963 9104 0423 4073 7673 6784 0409 0635 3337 2073 7109 3238 6838 4560 7465
Don't Forget to rate me dear
thnx
Nov 07, 2009 | Adobe Photoshop CS2 for PC
RCA Universal Remote Code
Here are the codes for Philips. If these do not work you have to use the code search feature.
Philips........002,006,007,010,011,013,016, 033,035,037,038,043,066,073
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD,
SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button,
for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-7.
Nov 12, 2008 | RCA Universal Remote Control
Celestial HD Digital Television Receiver DVB8800HD
Normally, there are 2 ways to hook these devices up. One is the component cable that has 3 colors, red white and yellow. these color codes match an aux. input on the TV (or vid1 or vid2) You need to change the TV input to whichever you used by the remote or maybe under Ch2 (4,3,2,vid2, vid1, aux,111,110,etc) The other way is to use the round 4-5 pin S-video instead of the yellow jack, that is self explanetory. The 3rd way and this depends on your TV and receiver is to use the HDMI, composite or DVI cable connection. These are only for Hi def players and will be either a large multi-pinned computer type plug, 5 colored/lead "octopus" cable, or a smaller D shaped high density cable with the row of contacts inside the plug. In any case you need to tell the TV which input you are using.
Once you get the TV to show a picture of the receiver, then you autoprogram the receiver with the remote under setup or other menu.
Jul 24, 2008 | Televison & Video
Instructions manual in English
Find the product number at the top left of the bar code on the bottom of your base unit.
Finding the product name/model number:
  1. Look on the bottom of your phone for the serial number sticker.
    (If you have a multi-handset unit, it will be on the main base.)
  2. The product name is in the top left corner of the sticker, above the bar code:
Once you have the specific model number go to this web page and follow the list down until you find your model and follow the list down until you find your model, click on product details. You will see the link to the manual at the top right of the model page, which is a PDF file. You can get the latest version of Acrobat PDF Reader at this location here..
Otherwise, if you would send me the model number as described above in a comment using the box below I will post a direct link for you.
Regards,
Worldvet
Jun 04, 2008 | Uniden Cordless Phone
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Mar 19, 2008 | JVC RM-C18G-1H Remote Control
Sony PFM-42V1 42 in. HD-Ready Plasma Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
