Question about HP Officejet Pro L7680 All-In-One Printer
Receiving a Save Failure General Error when trying to scan to any memory device on my HP L7680
4 Suggested Answers
SOURCE: HP L7780 WONT SAVE SCANNED FILES
New FIRMWARE UPDATE available from HP (released 7-16-08) which resolves the printing to readable pdf file issues available at:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-62339-1&lc=en&cc=us&dlc=en&product=2512010&os=228&lang=en
- or -
go to http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
enter your printer info (i.e. - L7780)
at the Software and Driver Dowloads page, select your operating system
under Firmware click on HP Officejet Pro Firmware
under Step 3 Obtain Software click on the download and save
Installation Instructions
1. Switch on the HP Officejet Pro L7700 series printer and wait until the printer is READY. [The Power light should be on]
2. Double click on OfficejetProL7700_R2006PxN.exe to launch the HP Firmware Download Utility. A list of HP Officejet Pro L7700 series printers detected will be displayed on the screen.
Note: If the Wired network printer you wish to upgrade is not displayed in the detected printer list, click on the Find Printers on Network button to scan for printers connected via the wired network.
3. Click on the checkboxes on the left to select single or multiple HP Officejet Pro L7700 series printers you wish to upgrade.
4. Click on the Download button to start the firmware flashing process.
5. Message showing "Successfully downloaded firmware to the printer" will be shown. Firmware flashing will begin. CAUTION! Do not interrupt the printer during the upgrade process. Printer maybe damaged if power is interrupted during the firmware upgrade process.
6. When the printer has sucessfully completed the flashing process, it will automatically print out a Self Test Diagnostic Page, that will show the new firmware version.
Posted on Aug 08, 2008
SOURCE: Unable to scan to HP Office Jet Pro L7680 All in One
I've the same problem.
I've solved this problem by using Vuescan 8.5, this prog can scan using the scandriver from HP
Success
Martin
Posted on Dec 30, 2008
Riztech
  • 731 Answers
SOURCE: I'm getting the error message: "save failure"
If your card has a small switch on the side, make sure that the switch is in the unlocked position.
Regards
Riztech
Posted on May 23, 2011
Regards
Riztech
May 23, 2011 | HP Officejet Pro L7680 All-In-One Printer
Will not turn on after a general power failure
HP support recommends:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01321436&cc=us&lc=en&dlc=en&product=2512009
I hope this helps!
Dec 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
Error 8,[ (4,0 -2147023170) ]
Cabgal .... what are you talking about? What you said makes no sense.
Explain yourself better or don't post!
The error is due to lack of memory needed to save/process the scanned pages. If you are scanning a full size book ... try limiting your scan to no more than 100 pages. Before you attempt to scan again ... power cycle the HP printer/scanner. Then run %temp% and purge all of the files listed.
Dec 06, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
I am having problems scanning photos onto my laptop (MacBook). I keep receiving Memory Device was not found when I attempt to scan and save to a memory device. What is the problem?
if you are using a wireless printer you still have to connect the printer to the computer using a usb cord to scan. in otherwords, the scan function is not wireless.
Aug 16, 2009 | Office Equipment & Supplies
Im having trouble scanning on the hp 7590 printer
Kindly reinstall your HP 7590 Printer to refresh and fix the error or corrupted files in your driver in order to run your device properly. Make sure also that the driver you install for your printer is support with your Current Operating system to minimize error and malfunction of the device.
Thanks
Jul 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
Success
Martin
Nov 19, 2008 | HP Officejet Pro L7680 All-In-One Printer
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp 7680 give 'General Error, error saving file'
There is a bug in HP firmware that doesn't allow duplex scanning to memory cards. Once it happens, you need to power down and power on the scanner. (and on a couple of occasions, I had to reformat my memory card)
Jun 28, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP C6180 won't scan to word or document viewer etc etc
the save as function is in the print/scan manager, not the software..you'll need to point it to where you want it to save, and also what format
May 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
Scanner component stopped communicating
well, reinstall the software and see if it will work.
Aug 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP Officejet Pro L7680 All-In-One Printer Logo
209 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
