Question about Dishwashers
I have an LG dishwasher, model LDS 5811ww. The machine fills with water, then stops filling when the error code IE comes on. I have cleaned the inlet filter and the whole inside of the tub, by taking apart the sump filter. There is good water pressure filling the tank. When I turn off the power and restart any cycle, the pump will empty the tank, then begin filling the tank again...until it is stopped by the error code IE again coming on. The other thing I notice is the water level in the tub. It appears to be right up to the level of the door. Is it possible that the error code is shutting off the cycle because the fill level is too high...a switch is not shutting off the filling of the the tank? There does not seem to be a problem with the pump or the filling with water, but the transition from filling to pumping in the wash cycle. Thank you.
  • 8 more comments
  • lizellis65 Apr 30, 2010
    Well now that I know that there is such a sensor as a water level sensor, that makes sense. What is the action you recommend to take? Is it possible to clean this sensor? Or does it need to be replaced? Thank you.
    What is your recommended action? Clean the water level sensor.....or does it need to be replaced (as in - not possible to clean it) ? Thank you.
    Well, this info and advice makes sense, so I will try to clean the water level sensor and see what happens then. Thanks.
    Thanks for the info and advice. I will try to clean the water level sensor, or if it looks like it needs to be replaced I will order the new part.
  • lizellis65 May 05, 2010
    I disassembled the input water tank and cleaned it....so water level sensor appears to be functional. This did not fix the problem with error code IE....it still comes on.
    What's next?
    I cleaned water sensor level tank and swtich...that did not help.
    cleaned water input tank and water level sensor.....appears to be functional. Error code IE still comes on.
    I cleaned the water level sensor and tank as you suggested.........this did not fix the IE error code problem....it still comes on and interrupts the cycle between filling the tank with water and the wash mode starting.
    Do you think it could be the water level sensor itself? Anyway to check this? I have figure out how to work the test mode if that is of any help. Or do I need to replace something?
  • lizellis65 May 06, 2010
    water level sensor is a tank with a small float in it that activates a micro-switch as the float rises. Is testing this switch as you describe.......with an ohmeter? And what am I looking for when I use the ohmeter? What kind of numbers tell me if the switch is good or not? I am confidant I can repair this unit if I can just narrow it down to what is causing the malfunction indicated by the IE error code.
    Removed door and checked wires.....no problem there. Water does fill up tank.....no problem with water inlet valve. Error code IE interrupts when tank is full.........or perhaps IE comes on because the water level is getting too high, and IE shuts it off..? I have been through all the test codes and everything in this machine works when tested.......though there are different lights associated with the test than the service manual lists. But I can determine that the major functions all work. I am thinking that perhaps the problem lies with the water level sensor micro-switch. I wonder whether IE comes on if the water level in the tank gets too high?
    However, error code FE is specifically about excessive water level and it seems that error code would come on if that were happening.
    Would you suggest replacing the water level sensor microswitch? It should be fairly inexpensive part, as it is a small simple switch.
    thanks.
  • 11,896 Answers
Sounds like you either have a dirty or faulty water level sensor or water temp sensor. Most likely a dirty or faulty water level sensor
Posted on Apr 30, 2010
  • 4 more comments
  • Nate Stansfield
    Nate Stansfield Apr 30, 2010
    If you can find it, then you can clean it with rubbing alcohol. Sometimes cleaning works, and some times it's pitted or corroded so bad it needs to be replaced.
  • Nate Stansfield
    Sounds good. If you ever need anything else, come back anytime!
  • Nate Stansfield
    You may find this site handy as well
    http://home.howstuffworks.com/dishwasher...
  • Nate Stansfield
    Nate Stansfield May 05, 2010
    I would test the water level sensor with an ohmmeter. Testing the resistance by placing a probe on each side of the sensor connections. A bad sensor or dirty/corroded sensor will cause these problems.
    You can also look at howstuffworks .com which has some good diagrams and such. Let me know if there is anything else.
  • Nate Stansfield
    Nate Stansfield May 06, 2010
    Did you
    "Measure the electric resistance of Inlet Valve. (950-1300 ω)"
    Is there any water coming in? If yes - could be flow meter. If no, could be water safety shut off valve or connecting wires.
    Also, remove the door panel and inspect the wires near the bottom of the door.
    the wires get buried in the tar like insulation causing the wires to
    break as the door is opened and closed.
    Also check here:http://www.yellow-mini.co.za/dishwasherf...
    andhttp://lgknowledgebase.com/kb/index.php?...
  • Nate Stansfield
    try replacing the water level switch or test it with an ohmmeter.
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
My dishwasher is an LG LDS 5811WW it reports an IE reading after one minute. Any help?
check clogging of water inlet hose ( or hose twist or freezing)....check water supply
Oct 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
We have an LG lds5811ww dishwasher with IE error
check for voltage at the water valve when it should be filling Try disconnecting the Water Valve outlet from the DishWasher and run the output into a bucket if all is well with the valve then remove the door panel and inspect the wires near the bottom of the door. the wires get buried in the tar like insulation causing the wires to break as the door is opened and closed.That tar like substance is one of the worst things they could of ever put into that machine causes the wires to break apart adn become brittle
Apr 30, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Hi there, Ok, i think i'm getting close to solving this problem. I have an LG dishwasher- Model # LDS 5811ST. I have stripped it down and clean all hoses etc. It is running fine through all the cycles....
try adding some more water to the machine after it has done the fill cycle do not over fill it. if there is no change in the performance the you need to replace the main wash motor.
if there is achange the you need to change the fill valve
Apr 06, 2010 | Dishwashers
Does not fill with water e1 code
1E means - Water inlet problem >Condition : Not reached to the normal water level in spite of 10 minute water supply
Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
Mar 29, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
IE error code
IE. is inlet water valve error.
Make sure someone did not turn off the water to the washer!!!!
Remove fill hoses and check filter screens on washer and fill hoses and clean if needed.
If problem continues water valve may need to be replaced.
Jan 16, 2010 | LG Washing Machines
LG LDS 5811ST still getting the IE error after several fix tries
If Hall sensor is OK? Air break replace next PCB
if there is enuf water ?
Aug 18, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
IE error code, machine keeps on draining
It sounds like the flood switch in the bottom of the washer is activated. check for water in the base as the machine if maybe leaking. This is a Dishwasher?
Feb 24, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Lg LDS 5811st IE code
With an LG 5811 diswasher, when the IE error code is not caused by kinked hot water hose or blocked screen, the next step is to measure the electric resistance of the Inlet Valve. (950-1300 ohms)
Dec 05, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code IE
a pressure sensitive dome is common on some units. as pressure builds, an air switch is activated.
otherwise there has to be a water contact switch.
the air switch dome can be located near the pump under the unit.
good luck
mark
Nov 11, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
Owen Barnes
