Question about Refrigerators
I have a kenmore 25352642303 the frig is no longer cooling or freezing like it should.It will start and run for a couple of seconds then quit.Could the starter switch be bad on the compressor
    Problem Solver:
  • 7 Answers
Possibly. But if it was completely bad the compressor would'nt do a thing. If you have a hard start cap. for a small appliance try that it's cheaper than replacing the switch just to find out your compressor is low on charge or bad all together. With a low charge the compressor will heat up and trip a thermal limiter. I believe your fridge is a sealed unit meaning a freon recharge is not really an option. If a hard start works, thenI would replace the switch.
Posted on Apr 30, 2010
Kenmore side by side freezer not freezing
I have had that problem when my Kenmore frig was surrounded by too much stuff that prevented air flow to the coils. It was also a problem when I had it on carpeting. I put a wood panel underneath the whole frig and cleared away all the clutter.
Mar 22, 2014 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore sidebyside 106 is freezing wide open on freezer side and barely cooling on frig side. there is ice in venting on the frig side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Kenmore 53642 / 53644 Side by Side...
Cooling and freezing problem
When the frig stops cooling properly, is it running at all? If the freezer fan is running and it is not cooling, you can rule out the thermostat and the defrost control. It would be a hard starting compressor or condenser fan. If the frig is not running, then it is likely the thermostat or your electronic defrost control. The defrost control is right behind the thermostat in the same housing. When you play with the Tstat, do it carefully as not to jar the defrost control. If the frig comes on, replace the thermostat.
Mar 23, 2009 | Kenmore Refrigerators
Kenmore side by side frig not cooling in frig comparment and
Something has failed in the defrost circuit-
Defrost thermostat
Defrost heater
Defrost timer
Reply back if you know how to diagnose electrical circuits, and I'll help you further.
Feb 01, 2009 | GE GSS20IEP Side by Side Refrigerator
Freezer and frig is not working
I would start by pulling it out, removing the lower back panel, and see if the compressor is running. It is the black ball on the left side. If it is not running, check voltage at the two wires at the compressor. If there is voltage, try a new overload/relay kit. If there is no voltage, try a thermostat. If the compressor is running, check the evaporator behind the rear freezer panel to see if it is frozen solid, if it is, replace the defrost timer.
Oct 26, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
Dec 31, 2007 | Refrigerators
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
