Question about Canon imageRUNNER 5000 Copier
Using as a printer on 3-fold brochure
I'm trying to send a 2 sided 3-fold brochure to the copier from my computer. What setting needs changed to rotate one page so it prints correctly?
  • 34 Answers
From your print menu properties change it from short 2 sided to long 2 sided or visa versa
Posted on Apr 30, 2010
Need help to print brochures
You can take help from a brochure printing company that would provide you best attractive designed brochures for your business or service.
I can suggest you best template collection that you can use as a base template or for inspiration.
Brochure Templates PSD would provide you a wide range of templates which is designed carefully with best fonts, colors, and layouts.
Mar 12, 2012 | Office Equipment & Supplies
Printing Legal size brochure (landscape) that gets cut off
readjust the margins in the printer page set up just before printing
Sep 08, 2017 | HP Inkjet 1200D Printer
Need tutorial on making 3 fold brochure in Qurk Express 7 or 8
If you are doing an 8 1/2 x 11 sheet with 3 panels, you need to set-up guides for the folds first.
1st fold is 3 11/16, 2nd fold is 3 11/16 from the 1st, last panel will then be only 3 5/8 wide. This allows it to fold inside and not bend.
The back side will have the folds reversed. To be safe, your columns should be no wider than 2 7/8 to allow for gripper on press and to stay away from the folds so nothing ends up in the crease.
Nov 18, 2009 | Computers & Internet
Need tutorial to make a 3 fold brochure in Qurak express 7 or 8
1. Go to: http://www.48hourprint.com/quarkxpress-templates.html
2. Scroll down to the BROCHURES Section.
3. On the 2nd item (Letter Tri-Fold) click on the file folder icon on the end.
It gives you a jpeg & png image file to place inside of Quark as a guide as well as instructions in a PDF file format.
Konica minolta 600 has problem printing duplex mailmerge and tir
CAUSE: The tri-fold printed on side is set incorrectly on the machine.
SOLUTION: To change the tri-fold from printing inside fold to printing outside fold, perform the following:
1. Press the Utility key.
2. Select Admin mode and enter the password.
3. Press Copier Setting.
4. Press the down arrow.
5. Press Tri-Fold Printed on Side Selection.
6. Press either INSIDE or OUTSIDE.
good lock
Feb 28, 2009 | Panasonic DP-C264 Copier
Paper fold
when you use the by-pass it's ok. when using tray paper z folds.
1- change feed & sep tires ( timing off)
2- bad seperation, roller or seperation assembly is bad or needs adjustments ( adjust in service mode or change)
Jun 20, 2008 | Canon imageRUNNER 400S Copier
Printer issues
If you are using Glossy paper, when you go to print make sure to go into the printer Properties from the Print dialog box and select Glossy paper in the type. This will put the printer into it's highest print quality mode.
So from most windows applications, it would be :-
CTRL-P (to print with dialog box for changes)
Click on Properties
Select a Media type of glossy photo paper
Select standard or high print quality.
p.s. you may need to experiment which if the media types gives you best quality for the paper your using, unless it's Canon paper and then just match it up.
Oct 29, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Oct 09, 2007 | HP Color LaserJet 2600n Printer
Lost reverse side printing option
Yepperz
The double sided printing option relies on Status monitor working correctly. If information cannot travel from the printer to the computer, the option will be greyed out.
Make sure you have a direct connection to the computer without any hubs. If that doesn't work, try the following.
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Sep 07, 2007 | Epson Stylus R265 InkJet Photo Printer
Canon imageRUNNER 5000 Copier Logo
78 people viewed this question
old marine
old marine
