Question about Intel Vantec AeroFlow VP4-C7040 Premium CPU Cooling Fan with TMD Fan&Copper Core for Pentium 4 Socket 478 CPU Fan, CPU Cooling Kit, Cooling Fan
No audio output in my pc - Intel Vantec AeroFlow VP4-C7040 Premium CPU Cooling Fan with TMD Fan&Copper Core for Pentium 4 Socket 478 CPU Fan, CPU Cooling Kit, Cooling Fan
  • yadayada
    yadayada May 11, 2010
    is the sound turned on?
  • 981 Answers
Weird category. Intel Vantec CPU Coolers! If you didn't burn out the output bridge of that audiocard (it's easy to install another USB audio device if you did) just install drivers for your audio device, connect it to an amp, and have speakers connected to the amp!
Posted on May 02, 2010
Audio output and audio input
Laptops have limited audio input and audio output.
They have a stereo headphone output and a mono mic input.
If you want something bettr then i suggest you install a PCMCIA audio card and driver.
Google search the Internet for these devices and you can compare what is available.
May 12, 2012 | Computers & Internet
How to hook up my pc's audio to rca rs3531 to
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level (AUX in your case) input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
http://www.retrevo.com/support/RCA-RS3531-manual/id/19240dj989/t/2/
Jul 26, 2011 | RCA port Turntable with CD&Digital Radio...
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
How to connect the gemini to the computer
Easy.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The Gemini's Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select Line In.
http://i.ehow.co.uk/images/a04/fa/r2/subwoofers-as-home-entertainment-set-1.1-800X800.jpg
The Gemini's Output (Record Master) would perform similarly if adapted to your PC's audio input, whatever that may turn out to be (usually Mic, maybe Line In).
Mar 12, 2011 | Philips Gemini CDM-500
Can u hook it to a computer for sound
More-advanced sound cards would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
A digital-capable receiver would accept 44.1 kHz for normal CD or DTS sources. Some diddling with the output sampling frequency might allow digital multichannel audio to be decoded by the receiver.
Feb 11, 2011 | Harman Kardon AVR 430 7.1 Channels...
I just bought the Sony MHC-EC99i and I don't know how to connect it to the tv so I can hear the audio from the tv to my speakers
Not knowing anything about your TV...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCEC99I click on "Operating Instructions"
Look at the section: Using Optional Audio Components.
Assuming your TV has an RCA audio output or headphone output, connect to the PC In. You might have to get an adapter. Select PC In to hear it. make sure the TV's internal volume controls are sending a "Fixed" audio output or its volume control will affect the output. Mute the TV or turn its speakers down.
Jan 16, 2011 | Sony Audio Players & Recorders
My pc says no audio output device is installed
You have to install the audio driver for the audio device first. As for the output audio it is for speakers connect/plug into to the output audio port.
Aug 06, 2010 | Microsoft Computers & Internet
Can i record audio from my pc to my sony rcd-500c
You can record any audio in the world on your CDR as long as it can be connected via either RCA or digital audio cables.
Depending on your PC's sound capabilities, you should have at least a headphone output that can be adapted to an RCA cable, or you may have an actual Sound Card with RCA audio outputs. And you may have a SPDIF (coaxial) digital audio output that you could use but you have to go into the software controlling the sound card to make sure the digital bitrate is compatible with the CDR (44.1mHz).
Go into your PC's Audio Property controls and make sure the outputs are all on and the volume is all the way up.
May 28, 2010 | Sony RCD-W500C 5-Disc CD Recorder
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Connecting audio from pc to receiver.
What does your sound card have for audio outputs? Mine (M7250N Media Center) has all the expected 7.1 analog audio outputs AND a digital S/PDIF audio output that I run to my receiver's coaxial digital input.
Even if you have just 2-channel audio on your PC the headphone output can be used with an adapter that makes it conenct to a standard RCA audio cable. Run it to any available Linme Level input on the Denon. Get into your sound controls on the PC and make sure your Master Volume is unmuted and adjust whatever else applies to your machine that may affect the audio.
Your monitor is not really a player in this scenario.
Apr 29, 2010 | Denon AVR2310CI 71 Channels Receiver
Computers & Internet Logo
104 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
