Question about Canon PowerShot G11 Digital Camera
What is the difference between high and low level formating of SD cards on my camera I can chose either but dont know what the difference is
    Guru:
  • Canon Master
  • 1,705 Answers
Here's the wiki-pedia website explaining the difference:-
http://en.wikipedia.org/wiki/Disk_formatting
Basically low level formats, format everything on a drive/card right down to sectors while a high level format just re-instates the file system.
As with wiki-pedia, go for the High level format. Only use the Low level format when you're desparate and nothing else seems to work.
Posted on Apr 30, 2010
I have deleted all the photos on my sd card & now it's saying card error, why?
Say car error bacause card has memory inconsitency. Try format on a computer, using a USB memory reader to Fat32
Apr 20, 2015 | Cameras
A write protect
Or check the Lock switch on the card is in the up position, like the one on the picture on the left.
This is how the switch should be.
No switch on the card is the same as locked.
Be aware you can format a card in a computer or even in another camera. Before you start using the card in your camera, use the format option in your own camera. Some camera's won't work if the card is not formatted in the own body.
Apr 16, 2015 | Cameras
SAMSUNG D760 HOW TO DELETE PHOTOS, IT SAYS CARD LOCKED.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 19, 2014 | Cameras
I've tried formatting a new san disk 4gb card and still reads "unable to use card" what do i do?
You haven't told us what kind of camera it is, but I can guess at the problem. There are two possibilities.
1. Your camera will only read SD cards, not SDHC cards. You've just bought a new memory card, not noticing that it was SDHC. The new cards don't work in your camera, not because they or the camera are broken, but because they're not compatible.
Cards up to 2Gb are generally SD. Cards over 8Gb have to be SDHC. 4Gb cards can be either SD or SDHC, but are almost always SDHC because they're cheaper. (I would avoid the rare, expensive, and problematic 4Gb SD cards.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it. (If it does, it probably means that they made a 4Gb card, but there were some error locations and so they disabled half of it and packaged it as a cheap-brand 2Gb.)
2. You formatted the card NTFS, whereas the camera needs FAT32. You can format the card using Windows, but there is a complication: Windows defaults to "NTFS" when formatting, but memory cards normally use FAT32. Before you attempted this, you should have connect the card, and checked the 'properties' on the drive that appears. It probably said "FAT32". In this case, you could have gone ahead and formatted the card, but be sure that you chose "FAT32" from the drop-down list. If you format it NTFS, your camera won't be able to read it!
In this case your solution would be to format the card again, but using the FAT32 format.
You might find it useful to check your camera on dpreview (dot) com, and see if the memory card type is shown as just SD or SD/SDHC.
Jan 20, 2011 | Cameras
CX7525. Inserted new 4gb sd card. Camera says it needs to be formatted. When I click on the "OK" button to format, it says "card needs to be formatted" again and again. Will not format...
There are no 4GB SD cards. "SD" cards larger than about 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 29, 2010 | Kodak EasyShare CX7525 Digital Camera
The screen say's memory card error, card locked, but it is a brand new card. I unlocked it and it still says error
I think you have a HC card, Any SD memory card about 2GB runs at a different compression rate to the 'normal' SD cards. ie High Compression. If you do have a larger card in an older camera it will not read, The camera cannot access the information, and it will not work. If it's a 2GB or smaller, try formatting the card - Go to your review menu, press setup and chose format from the list. This should sort it out.
Jul 25, 2010 | Canon PowerShot SD600 Digital Camera
I keep getting the error msg memory card cannont be read
Your camera is only supporting: SD/MMC up to 1 Gigabyte
The card that you currently have might be high speed. All should be sorted if you change the SD card to the supported MMC SD card up to 1G. There is a lever on the SD card this one might need to be changed.
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Jan 19, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Xacti VPC-HD1000 "Problem with SD card" "FORMAT / FULL FORMAT"
This card is not compatible with your camera try another brand!
This should fix ya! ( ( all sd cards may look alike but they are not!)
Dec 14, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Jpg files corrupt
After you've donloaded your pictures, have you tried formatting your card in the camera? Press the Menu button, then go to the settings (tools) menu. Go down to the Format option. Select "Low Level" format if available in your menu. Again make sure that you have downloaded your pictures first as this will also erase your card.
If the above doesn't work, have you tried using an SD card reader? If so, the next thing to try would be a different card reader. And finally, have you done a recent sweep for spyware on your computer. Spyware can cause temporary hangup/hiccups that could potentially corrupt your download.
May 27, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Sd card
To reformat the card so the Nikon Coolpix can use it you can use the DOS command 'format' e.g. format g: HOWEVER the default DOS format is FAT32 which the Coolpix will not read. The SD card needs to be formatted in FAT.
Open a DOS command window and type:
Format 'volume' /fs:FAT
Where 'Volume' is the drive letter to be formatted. On my PC this was 'G'. This may be different on your PC. Make sure it isn't an internal drive e.g. C or D!
e.g. format g: /fs:FAT
The card then works OK on the CoolPix
Nov 27, 2007 | Cameras
Canon PowerShot G11 Digital Camera Logo
223 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
