Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Computer when i switch my pc on it says keyboard failure
    Guru:
  • 377 Answers
Hi dear
try to use a usb keyboard connector
oke
Posted on Mar 25, 2008
Turns off after 5 beeps
It is either CPU or Motherboard failure or your keyboard controller failure. Keyboard plugs directly into your motherboard or through a USB port. Try a different keyboard first and if that doesn't work then it may be time to look into getting a new computer. it will drive you crazy trying to diagnose the problem. Good luck ........
Apr 05, 2014 | Acer Dt.vfmaa.008 Veriton X4620g Desktop...
Mac keyboard not working through SV211KDVI on windows
Chances are that the distance between the keyboard & the PC computer is attenuating the signal of the keyboard below the threshold (or level) required for interfacing with the PC computer.
Perhaps a shorter KVM cable between the KVM unit & the PC computer could be helpful.
Jan 18, 2014 | StarTech.com (SV211KDVI) 2port KVM Switch
Dell dimension 2400 freezes up shortly after boot. I replaced cooling fan but error log shows keyboard failure.
if you see lights get on Keyboard.. your motherboard is fine.. else it is your Keyboard or Super I/o Chip that is not working..
Mar 27, 2013 | Dell Dimension 2400 PC Desktop
Keyboard failure
This may be an issue with your usb drivers. Update those first, then if that fails, I would try one of those adapters that goes from USB to the old school mouse and keyboard connections and plug that in to see if it works.
Sep 24, 2012 | Dell Inspiron 640m Notebook
When switch on desk top computor it bleeps saying unable to detect mouse/keyboard but mouse lights up
This can be caused by loose connections or a failure on the main computer motherboard. With the computer off pull the keyboard and mouse connections off and then reinsert them. Boot the computer and see if it finds them. Also try a differant keyboard and mouse.That will tell you if it is one or the other that has the problem. If you still cant use the keyboard or mouse then you have a more serious problem and are most likely looking at replacing the motherboard. Check to see if you have any warrenty either from IBM or the store you bought from.
Mar 23, 2010 | E-Machines eMachines Desktop PC
Repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Total keyboard failure
Switch off the notebook, remove battery and press power button for 20 seconds to discharge the unit properly. Remove keyboard carefully and re-seat the keyboard ZIF connector. Hope this will resolve your issue.
Regards;
Hasan
Dec 29, 2009 | ASUS Eee PC 1000H Laptop
Keyboard failure on rebooting
reseat the keyboard connector to the pc or try another keyboard
Dec 16, 2008 | Dell Inspiron 530s Desktop Computer
Its a Dell XPS 400
There is no way around a bad keyboard, you will need to get a new keyboard to continue.
Feb 19, 2008 | Dell Dimension XPS 400 PC Desktop
Can's switch without it switching back to first PC
Sadly, it is probably the KVM as this particular model has a string of failures and is only rated 2 out of 5 stars on Amazon due to poor performance. :( http://www.amazon.com/Belkin-F1DK102U-2-Port-Switch-Cables/dp/B0001JXAQ6/ref=sr_1_1/105-6999807-3936431?ie=UTF8&s=electronics&qid=1187826004&sr=8-1 What I would do first is plug in Computer 2 directly to the monitor, keyboard and mouse with no KVM. If those work fine, it is probably not a computer issue; if you don't get video here, then it is a seperate issue with that PC. If Computer 2 is working, plug both computers into the KVM but switch the cables (plug Computer 1 into the KVM using Computer 2's cables). If Computer 2 shows up and can't switch to Computer 1, then it is the KVM messing up.
Aug 21, 2007 | Belkin F1DK102U 2-port KVM Switch
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
20 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
