Question about Garden
Troy Bilt model 60TG I hit a small piece of wood and the tractor
Troy Bilt model 60TG Tractor I hit a small piece of wood and the tractor stopped running. When I try to restart it, nothing, the starter wont attempt to start.
  • 196 Answers
If you haven't already, check to see if there is a hunk of wood wedged between the blade(s) and mower deck. I've seen that happen. I pried the hunk of wood out with a crowbar and life was good again. The second time, someone ran over a campfire log they didn't see under leaves last fall and bent the blade spindle. It basically froze the spindle in place even though there wasn't anything wedged in there. I removed the belt from the top of the mower deck and then it started just fine..... although the blades and shaft were toast and had to be replaced. If you can disengage the mower deck without removing the belt(s), try it if you haven't already. See if it starts that way. If not, the issue may be more serious such as a broken connecting rod in the engine. Try the simple stuff above first to troubleshoot the cause.
Posted on Apr 30, 2010
Need diagram to replace tension spring for drive belt
Go to the manufacturersame website, enter in the the model number and look under diagrams for the pic of your tractor. My troy Bilt has 2 belts, one for the cutting deck and the other is the drive belt. I would replace both as the cutting deck needs to be removed and it's fairly simple and will save you time. It sounds let the drive belt is the reason for the tractor not moving. Hope this helps.
My tractor is a 2007 troy Bilt super bronco with a new fresh installed motor.
Nov 03, 2015 | Garden
Where can I get all three belt diagrams for a troy built bronco riding lawn tractor model# 13AV67KG
Troy Bilt Deck belt Replacement - YouTube
? 11:46
www.youtube.com/watch?v=w3SrErGTyoY
Apr 1, 2014 - Uploaded by Murray Mayhem
I got a good one troy bilt bronco having problems finding the right deck belt for it. I use the model number under the seat but they are too long ..
Jul 09, 2015 | Troy Garden
I need to replace the blades on my Troy Bilt 46"
If you are going to replace them yourself, you can go to www.jackssmallengines.com and should be able the look up the parts diagram by model # and order then on their web sight.
Aug 18, 2011 | Troy Garden
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Just purchased Troy-Bilt Lawn Tractor from a friend. Can you tell me how to replace loose transmission belt so it will go forward. Belt is loose.
If you have a lowe's store near you they handle troy-bilt so get your model number off your tractor and they can get you the drive belt and a copy of replacement instructions.Thank you.
Apr 15, 2011 | Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt Horse Lawn Tractor Transmission problems
you need to screw the transmision adjustment in so that it is push all the way in to gear.
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
222 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
