Question about Goodman CKL60AR60 Air Conditioner
Where is fuse located on goodman ckl60-1 ac unit?
  • Jim Glover
    Jim Glover May 11, 2010
    What fuse? There can be an automotive style fuse in the board.
    Novelist:
    Champion:
  • 246 Answers
I'd be surprised if you had a fuse in either the outside or inside unit. Typically the fuse(s) are mounted in a gray electrical box (on the house) near the outside unit.
You can usually - easily see the fuse box but if you don't just follow the electrical conduit from the outside unit - to the fuse box.
good luck!
Posted on May 05, 2010
Goodman AC unit
It doesn't look like the other 4 were used. Unless when it got "yanked" it also got cut. I am betting you don't need them though.
May 14, 2013 | Heating & Cooling
Open rollout or open fuse on Goodman
the fuse is located in the circuit board in the blower compartment and the roll-out is located in the burner section and can be a reset-able switch style or the one time fuse link style which is a a small silver cylinder and is mounted in a ceramic piece and is held in with one screw. Both of these are mounted around the opening of the your burner assembly near the opening. This will be near the area of the gas valve.
Sep 24, 2012 | Goodman Manufacturing Goodman R410A 13...
I have a Goodman AC unit that isn't working. I believe its the fuse. My power went out and the ac unit stopped working. the first time the repair guy said it was the fuse. I don't want to spend...
Generally, the fuses are located in a box outside by the outdoor unit. The box has a door on it and you will probably have to pull a cartridge out and the fuses will be behind the cartridge. If you don't have an ohm meter to check the fuses , just go to home depot, lowes or another hardware store where they can check them for you. Be sure to check the circuit breakers too.
Jul 11, 2011 | Goodman CKL36AR36 Air Conditioner
Location of overvoltage protection
Go outside to the condensor, its unlikely that the fuses are there unless it is an older unit. Turn off the power and open the power disconnect box. That is one place the fuses or breaker could be.
In the house you should have an electrical panel usually grey in color. Open the service panel as it should be hinged. Most of the time the fuse or breaker is labeled AC Unit andThe rating should be
anywhere between 25amps-60amps.
Jul 20, 2010 | Goodman CKL24AR24 Air Conditioner
Unit will Not turn on
Hello. There is usually a separate circuit breaker in an electrical box near the outdoor component. Chances are it was turned off at that location for the winter. Joe
Apr 03, 2010 | Goodman CLQ36AR49 Air Conditioner
I have a goodman furnace and ac unit heat and fan work but soon as i flip the ac on it blows the 5amp fuse at the furnace
their is a control short some place check the control wiring . dog or rodents chewing threw it or shorted controls or thermostat id get service. Tom
Jun 24, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CK30-1A Central AC Unit will not run by thermostat
double check your t-stat wiring your not getting 24volts to the contact at the cond. unit outside
Jun 20, 2009 | Heating & Cooling
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
781 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
