Question about Acer Aspire 5000 Notebook
My cooling fan has quit and I require information about getting into the machine to change it. The fan part number would also be helpful
    Problem Solver:
  • 16 Answers
Find the fan same like ur laptop fan.fan part number is not important
Posted on May 01, 2010
Cooling fan wont turn on
have you tried changing your cooling fan relay
Mar 24, 2013 | Cars & Trucks
I have a 2007 kia sedona. the check engine light came on, the a/c starts to blow warm when stopping or at idle and it starts to run hot. when vehicle is moving it runs fine. I took it to autozone to check...
"I took it to autozone to check the engine light and it said that there is something wrong with the cooling fan circuit." AutoZone may have isolated the problem to the cooling fan circuit.
Jul 24, 2017 | 2007 Kia Sedona LX Minivan
C0040
The C0040 is a cooling fan failure code. Opening and closing the front door wil reset the code. Doing this while "bumping" the machine will restore the machine to operational MOST of the time. Cooling fan replacement will eventually be required. Resetting though can be accomplished in most cases.
The part number for the fan is 9313-1310-61 and here is a picture of the fan which is located behind the rear cover.Thanks
Feb 07, 2011 | Minolta Office Equipment & Supplies
Hi we have a toshiba laptop model number psmc6a-003q00s. what's happening is the unit is over heating and cuts out having to wait to cool down and restart the laptop. sometime the fan kicks in but does...
Hi Danial and Gin a,
Your right! It IS Overheating. Usually this happens by using a laptop on a bed or soft surface that doesn't allow the heat to escape from underneath the machine. If that is the case. Use a desk or table top to place it on. Here is what can happen. It can keep overheating and then after it cools down one day, it may be finished and not recover. So it is a serious matter to correct as fast as possible. Laptop repairs can be quite expensive.
Cleaning out the fan is an excellent idea. I would go down to your local Walmart, or computer store and buy a bottle of compressed air type cleaner for computers. I would blow the dust out of the fan. The third thing I would do is purchase a laptop cooling device that sits under the machine and helps cool it with its own fans. If you do this you should come out fine.
If you have been using the machine on a soft surface, putting it on a hard surface and blowing it out may be all that is necessary. Good luck,
Best Regards, Mark
Dec 26, 2010 | Toshiba Satellite P105-S921 Notebook
C 0040
Jun 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
Fluttering sound when trying to tun set on, never comes on and shuts down. Sounds almost like a motorboat sound, but not quite. Recent bulb change. Made sure all vents and air filter were cleaned. Took the...
Maybe the fan is going out. Since you said bulb change I assume your tv is a projection tv. If so I think those tv's have fans to help keep it cool. If the fan is not working properly or failing, the tv may be shutting itself off so further damage does not occur. Check the fan. What is the model number of your tv?
Mar 08, 2010 | Hitachi 43FDX01B TV
Cooling system fails
There are two fans in this unit. It was my secondary fan that had failed. The primary fan is the one on the bottom that you can see, and the secondary is in the back near the usb connectors.
You'll need to determine which one has failed. I was able to diagnosis mine by setting the power management features to Level 2 from 4 on the cpu, and the fan setting to "battery optimized."
In that particular configuration, I could hear a fan turning on, but it wouldn't run long enough to trip the error message. I was then able to use the machine in a very slow speed waiting for the replacement fan to arrive. The fan was about $35, but because of it being buried so far into the internals, it took me three hours to disassemble, replace, and reassemble the machine.
I used the pictures here: http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm as a guide for assembly and disassembly.
Oct 07, 2009 | Toshiba Satellite A45-S250 Notebook
Where are the cooling fan relays for a 1998 Cadillac Deville Northstar located?
Are you sure that you don't mean the cooling fan control module? It should be located up front next to the cooling fan. It is square shaped and has a long square shaped plug going into it. 00114_cooling_fan_control.jpgReads the temperature of the coolant and passes the information to the engine control computer (ECC). The ECC receives analog information and signals the cooling fan switch to cycle the cooling fan on or off, as required.
Jul 07, 2009 | 1998 Cadillac DeVille
GE jvm1653 fan quit
It is vital that the cooling fan runs, or the magnetron will be destroyed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
2004 Jaguar x type electric radiator fans not operating
check out with your dealer as you might have a recall to fix this problem.
XT303-S932
X-TYPE
DATE 01/03
MODEL
2002-03 MY
X-TYPE
VIN
C00294-C91719
Overheating - Cooling Fans Inoperative - Replace Module Prior To Retailing - Service Action S932
This Service Action Applies to Vehicles That Have Not Been Retailed
Issue:
The cooling fan module on X-TYPE vehicles may fail under certain circumstances. There are various root causes but the design and quality of the printed circuit board within the cooling fan module are the most significant. The NAND gate used in the circuit is detective causing multiple failure modes, this can result in high engine temperature and overheating due to the cooling fans not operating.
A change has been implemented in production from VIN C91720. On these vehicles a 'Philips' printed circuit board has been used that has a modified voltage spike protection strategy.
Action:
To prevent customers from experiencing this issue, install the latest specification cooling fan module on 2002-03 MY X-TYPE vehicles within the above VIN range that have not been retailed.
PROCEDURE
1. Install new cooling fan module (see Workshop Manual, JTIS CD ROM, section: 303-03, SRO 26.25.38).
Parts Information
Warranty Information:
Warranty claims should be submitted quoting S932 in place of the warranty fault code together with SRO: 26.25.38 and the relevant part number. This will result in a labor time allowance of 0.8 hours to replace the cooling fan module and payment for the part used. Should the vehicle be brought back into the workshop for this action alone to be undertaken, an additional labor time allowance of 0.1 hours can be claimed quoting SRO: 10.10.10 for drive in/drive out.
Warranty claims should be submitted quoting the information found in the table. This will result in payment of the stated time and, where applicable, parts/miscellaneous expense codes.
The options that allow for drive in/drive out may only be claimed when the vehicle has been brought in to the workshop for this action alone to be undertaken.
The SROs and parts items listed above have been included for information only, there will be no requirement to enter the parts or SROs onto the claim.
NOTE: Always perform a DDW claim search first to determine whether this service action has been performed on this vehicle. The warranty selection under the vehicle inquiry will give a listing of all claims against the vehicle. If this service action number appears in the program code field, do not perform this service action.
Dec 13, 2008 | 2005 Jaguar X-Type
Acer Aspire 5000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
