Question about Whirlpool GC5NHAXSQ
Whirlpool side by side Fridge Freezer S20BRBB20
I have a Whirlpool side by side model S20BRBB20. Freezer seems ok, but fridge is not cold enough and the water from the chilled water dispenser is not cold at all.
The fridge freezer is about 6 years old. Back brain was replaced under warranty in the first year and three years ago I replaced the front and back brain.
Is this another brain problem or could it be something else?
Thanks for any help.
  • meadowcat Apr 30, 2010
    Thanks for the reply myndow. I have already taken the back panel off the freezer and found no build up of ice. I left it turned off to allow it to defrost, but it has made no difference. The fan is operating. It goes off when I open the fridge door and comes on when I close it again.
    Problem Solver:
  • 7 Answers
Your fridge is simply not defrosting itself or moving air off the freezer coil. Try defrosting it and make sure the fan is operating. If the brains have been replaced already i do not think you should have to deal with them again unless consumer reports suggest otherwise.
Posted on Apr 30, 2010
Is there a separate freezer control to the fridge? fridge seems ok but with frozen bobbles on the back wall, but freezer doesn't seem cold enough?
Fixya is a great help when you provide model numbers. Like my help? What is the model number of the fridge?
APPLIANCE 911
Apr 13, 2016 | Refrigerators
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
My fridge/freezer model no.FRSS36AF25/3 - fridge section does not seem cold enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge not blowing cold air but freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
May 28, 2010 | Refrigerators
The fridge side is not cold enough, but the freezer seems to work fine
Make sure that the climate controls on the fridge side are set towards "coldest". If they already are, you might have a bad thermistor, which should be located behind the temp controls at the top of the fridge side.Fairly easy to replace.
Nov 02, 2009 | Whirlpool ED2FHEXN Side by Side...
User manual whirlpoolfridge freezer 20rid3 sf i have lost user manual
Call Whirlpool. The number should be on model tag inside freshfood. Either upper right or upper left.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our whirlpool 6 yr old refrig / freezer is not working correctly
Use a vacuum and clean under your fridge. A dryer cleaning brush will help make the job go much faster. Use a good light so you can get all the lint out. Give it 12 hours to level out. hope this is helpfull.. Saw
Aug 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Candy Fridge - The freezer part is not cold enough, fridge ok!
A couple of things to check-
- Is the condensor cooling fan running? This will be located to push air through the external cooling coils, wherever they are located.
- Does the auto-defrost timer work? It may have failed and stayed in a position that has left the heating elements (for defrosting) turned on.
- Does it seem to be running way too long and not turning off as it once did? This could indicate either a loss of coolant (would need recharge and leak detection) or the compressor is reaching its end of life. If the latter is the problem, expect a cost of $200-$400 US.
Apr 07, 2009 | Whirlpool Gold Series GI15NDXT 15"...
Roper whirlpool refrigerator
Mine is doing the same thing,started today. It is going to be the timer defrost or the cold control thermostat.Timer is $20. Thermostat is $55.Both are located on the fridge side about eye level by the light.They are underneath the plastic cover.
Mar 20, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Whirlpool GC5NHAXSQ Logo
331 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
