Question about Samsung L100 Digital Camera
My camera keeps turning off with a full battery and makes a beeping noise
    Guru:
  • 1,049 Answers
There is something obstructing the lens. Camera turns off if it can't extend and retract the lens. Turn it downward, try blowing compressed air around the lens itself, or if all else fails spraying around the base with a light dusting of CRT cleaner (90% isopropal alcohol spray)
Posted on Apr 30, 2010
4 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: turns on beeps lens comes out tries to focus
HI, this will occur when there ia a lens mechanism failuer. Inside the cam housing , there is a mechanism that is powered by a small servo motor. this mech can become lose or unstable, in return, jamming itself open or closed. When this happens, you will need to send it to the manufacture for this repair. they will replace the motor and mechanism as well. Contact Pentex for a repair ticket. they will refer you to a nearby repair depot.
Posted on Jun 10, 2009
squirt410
SOURCE: the camera makes a beep noise and turns off with
How long has the lens been open when this happens'? My Canon has a battery saving mode that it goes into within a minute or so. Does it turn off completly or can you 'wake it up again' by pressing the shutter button? It MAY be just a battery saving feature which, I think, you can change that option to a longer time by looking at your setup settings.
Posted on Dec 18, 2010
  • 11967 Answers
SOURCE: my camera makes 3 beeping noises, wont turn on * HELP
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 14, 2009
Blurry pictures and beeping noises
It could be the lens is damaged on the inside (Gears and so).
But before you make any conclusion. try to switch the camera to auto mode and make sure the camera is not in the macro mode.
To start, switch of the camera, remove the batty and leave it out several seconds. perhaps you also should charge the battery on an external charger,but if you are sure it is charged, after a few moment reinsert the battery. Then switch the camera to the automatic mode and check if it is not in Macro. (when you see the flower on the screen it is in macro)
If it is still acting the same you made the right conclusion in the question above. (I hope you are wrong but if not, you start looking for another camera)
Jan 26, 2014 | GE J1470S Digital Camera
My Olympus Camedia C-750 will not turn on. When I start it, the screen looks normal but then goes blank. it stays lighted and then beeps several times then makes a noise like a picture has been taken,...
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
Sep 05, 2017 | Olympus Camedia C-750 Ultra Zoom Digital...
My Camera Won't Charge!!!
Your batteries are dead. You can buy them buy doing a search for your model number on your camera, and it will tell what batteries to use.
Nov 30, 2009 | Oregon Scientific DS6310 Digital Camera
The lens and remains open and zoomed, but will not take photos. When I try to turn it off, it goes in for a second, then out, makes a funny motorized noise and then beeps. suggestions?
sounds like the battery isnt given it enough umphs to turn it on and off. try going into the compartment and pull up the spring alittle to make better connection on the battery terminal. or it could be the motor to the camera is wearing out and needs replacing. the beeping sounds like the battery issue tho.
Nov 28, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Camera not staying on LCD display message.
Remove the batteries and externally recharge them . Sometime batteries , in some cases can have a polarity change but then the camera may just not turn on.
Jul 27, 2009 | Canon PowerShot A470 Digital Camera
Samsung s860 makes beep noise and then turns off wont turn on batteries are charged
well i had the same problem it means it doesnt like that type of batterie i find alkyline works best
Jul 06, 2009 | Samsung S860 Digital Camera
Need help
Mine does the same thing. It takes a few minutes to realize it has new batteries. lol. Keep trying, it will eventually come on.
Sep 09, 2008 | Samsung Digimax D53 Digital Camera
It keeps making a beeping noise and wont let me record or do anything!
Try taking off the battery and reinserting it to see if it resets mech,If this doesnt work you wil have to bring to service.Dont go at it yourself as you could cause serious problems,
May 23, 2007 | Sony Handycam CCD-TRV68 Camcorder
Samsung L100 Digital Camera Logo
1,463 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
