Question about Nintendo DS Console
Nintendo wi-fi usb connector will not connect to my ds
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
If you are using windows please make sure your wi-fi adapter is atteched in device manager start>control panel>device manager
Posted on May 09, 2010
How can i connect my computer to my nintendo?
https://www.nintendo.co.uk/Support/Nintendo-3DS-2DS/Connecting-to-the-Internet/Connecting-using-a-Nintendo-Wi-Fi-USB-Connector-/Connecting-using-a-Nintendo-Wi-Fi-USB-Connector--243609.html
Mar 04, 2015 | Nintendo 3DS XL - Blue/Black
Error Code 51099
Unfortunately, that error code means that your router is incompatible with the DS. I had this problem when I played DS, and we ended up buying the Nintendo Wi-fi USB connector, which acts as a bridge to let your DS connect through the PC it's plugged into.
You can find a USB connector at most electronic stores, but you just need to make sure it is the official Nintendo Wi-fi USB Connector, not a cheaper substitute, as those WILL NOT work.
The other option is getting a new router, which is the better but more expensive option. Chances are, your router is pretty old or low quality if you're getting that error anyways, and buying a new one will fix that problem right up.
Apr 06, 2011 | Nintendo DS Lite Console
What does error code:51099 mean
Error Code: 51099
The only access point within range of your Nintendo DS is not configured or is not compatible with the Nintendo Wi-Fi Connection (such as those found in many Hotspots).
Where are you trying to connect from?
1. Wireless Home Router (please scroll down)
2. Nintendo Wi-Fi USB Connector (click here)
3. Hotspot (click here)
Using a router:
1. Please make sure that your router is not on our list of incompatible routers. Click here to view the list and locate your router (if available). If it is listed as "not compatible," then it appears your router will not work with the Nintendo Wi-Fi Connection. Consult the compatibility chart for recommended routers, or consider purchasing a Nintendo Wi-Fi USB Connector. If your router is not listed as being incompatible, please proceed to step #2.
2. Ensure your router has the latest firmware installed. Visit your router manufacturer's website and look for any updated firmware that may be available (these are typically found under "downloads" or by searching for your particular model number). Contact your router manufacturer for additional assistance.
3. Make sure that your network's name (SSID) matches exactly to what you have entered in the Nintendo DS.
1. Log in to your router using the default IP (consult the router?s owner?s manual for assistance).
2. Look for the section for SSID (typically in the "wireless settings" area).
3. After you find the SSID (network name), verify in the Nintendo Wi-Fi Connection Settings of your Nintendo DS that the SSID is appearing exactly as listed in your router. This includes making sure capitalization, spaces, or special characters match exactly.
4. Check Nintendo's router info for special notes, if available, for your router.
1. Click here to go to our Wireless Router Configuration page.
2. Use the drop-down box on the left to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing such things as the Transmission Rate.
5. Your router may not be assigning an IP address to the Nintendo DS. Try manually assigning an IP address to your Nintendo DS.
1. The first thing you'll need to do is find out what IP address your router is using. To do this:
1. Click the "Start" button in the lower left-hand corner of your computer.
2. Click "Run."
3. Type "cmd" into the box and press Enter.
4. Type "IPCONFIG/ALL" and press Enter. The IP address displayed of the PC will be displayed.
The IP address you going to assign to the Nintendo DS must be 10 digits higher than the PC?s. (e.g., 192.168.1.100 becomes 192.168.1.110)
2. You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this, please click here.
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Using a Nintendo Wi-Fi USB Connector:
* Does the Blue Wi-Fi registration tool icon appear in the system tray of your PC (typically this is found in the bottom right-hand corner of your computer screen, near the clock)?
1. Yes. If the connector has been inserted very recently, it may take several moments for it to establish a connection. Retry.
2. Yes. If the USB Connector is inserted directly into the PC, trying attaching the plastic extension cable that came with your USB Connector. Getting some distance between the PC and the USB Connector may help the signal strength.
3. No. Is the software installed? Is the USB connector inserted? Restart the PC, and if it still does not appear, we recommend uninstalling the software and installing the latest version. Click here to get the latest software for the Nintendo Wi-Fi USB Connector.
4. Yes, but it's gray. Is the USB connector inserted? Right-click the registration tool icon and choose to run the registration tool. If it does not respond, restart the PC. If it still does not respond, we recommend uninstalling the software and installing the latest version. Click here to get the latest software for the Nintendo Wi-Fi USB Connector.
Oct 24, 2010 | Computers & Internet
Trying to connect to internet error code 051112 - 1
Error Code: 051112 The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Connecting from a wireless home network:
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction.
  • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector, click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Connecting from a Hotspot
  • Ensure the Hotspot location does not require an internet browser to setup an account, accept a use agreement, or enter a password before accessing their Wi-Fi serice. If the location requires any of these items, you will not be able to connect to the Nintendo WFC.
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction. Signal strength can vary, depending on where the access point's signal is coming from. (Please do not sit or stand in places that will interfere with the location's customers or staff.)
  • Orientate the Nintendo DS so that your body or other objects (such as walls, plants, furniture, and other people) are not blocking the signal. Also, make sure there is no interference from wireless phones (cell phones are okay).
  • If the connection continues to fail, this Hotspot may have their router set up in a manner that is not compatible with the Nintendo WFC.
Aug 16, 2010 | Nintendo DSi Black Console
Error code:051110-1
Error Code: 051110 The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Jun 26, 2010 | Nintendo DSi Black Console
ERROR CODE051110
Jan 24, 2010 | Nintendo DSi Black Console
My nintendo DS can't find my usb connector
The wi-fi USB dongle comes with software, install that before plugging the dongle in. If you have lost the software, download it from Nintendo:
http://www.nintendo.com/consumer/wfc/en_na/customersupport/downloadUSB.jsp
After the software is installed, there will be a blue circular icon in your system tray (lower right, by the clock). Double click that.
Now turn on a game that uses wi-fi. When prompted to set it up, select the USB connector.
Your DS should show up on the program on your computer. Click it, and then select "Grant permission to connect."
It should run a test now, and all should be well!
Mar 10, 2009 | Nintendo DS Console
Trying to connect to wifi usb connector and keep getting error code 52203
I'm assuming you are talking about the nintendo DS. Here is the info on that error code straight from nintendo:
Error Code: 52203
The Access Point you are attempting to connect from is not connected to the internet or a firewall is blocking traffic necessary for connecting to Nintendo Wi-Fi Connection. What to do will depend on where you are trying to connect from: What to do:
  • Verify that your router is connected to the internet when attempting to connect to the Nintendo Wi-Fi Connection. If you are not able to access the internet on your computer, then there is a problem with your internet connection. Contact your Internet Service Provider (ISP) for more information.
  • America Online (AOL) broadband users may experience difficulties when attempting to connect to the Nintendo Wi-Fi Connection. Please contact America Online for assistance.
  • If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls and the Nintendo WFC, click here.
Connecting from a non-partnered Hotspot:
  • The access point at the Hotspot may not be experiencing problems. Ask the staff on site if their Wi-Fi network is up and running.
  • If the Hotspot's access point has a built-in firewall or other security that interferes with the necessary transmissions from the Nintendo DS, then the access point will not be compatible with the Nintendo DS.
  • Try another Hotspot. To search for known Hotspots in your area, click here.
Jul 16, 2008 | Nintendo Video Game Consoles & Games
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
