Question about Canon PIXMA MP600 all-In-One InkJet Printer
How do I fix error 6A00 on my canon MP600 printer?
Error 6A00
  • Joan Jameson
    Joan Jameson Feb 02, 2013
    To techguy123, your solution included a comment about "It turned out to be stuck in a kind of upward position" so I stuck my hand into the area of the base pad and felt abound in there until I heard somethink click. Problem solved. I had already cleaned the gunk out of there. Thanks so much!
  • 4,041 Answers
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
  • peter-sco909 May 03, 2011
    Thanks so much for your help with error code 6A00 called canon service ctr all they wanted to do was collect mp600r at a cost of £61.20 then would be plus parts.But with the information you provided managed to solve problem myself THANKS Peter Westcliff on sea
  • Boateng Kwabena
    Boateng Kwabena May 12, 2014
    thanks for the insight into this error, hope to solve this problem on my machine.
pineworks
  • 4041 Answers
SOURCE: Cannon Mp600. I have an error code 6A00
Try
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Posted on Jan 25, 2010
  • 26 Answers
SOURCE: How do I solve error message 6A00 on canon printer?
Turn switched it off, open the lid and manually slid the cartridge-tray to the left. Use a piece of tissue to clean the base-pad where the heads are stored. It turned out to be stuck in a kind of upward position and somehow the mechanism that moves the tray is released so nothing happens when you switch on the printer.
Touching it snapped it loose. Remove all ink residue, move the tray back to its most right position and close everything.
Please let me know.
Posted on Oct 05, 2008
pineworks
  • 4041 Answers
SOURCE: My Canon Pixma MP600 printer has an error coming
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Posted on Feb 10, 2010
pineworks
  • 4041 Answers
SOURCE: canon mp600 printer error code 6A00
Heello there
Error 6A00
Solution 1:
Solution 2:
Solution 3:
  • 41 Answers
SOURCE: my canon MP600 PRINTER
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Posted on Feb 23, 2008
Error code 6A00
I HAVE A CANON MP600 ALL IN ONE PRINTER. SCANNER etc., AND I HAVE AN ERROR CODE OF 6A00 COME UP! both green and amber lights flashing and will not allow me to print... can you please help
Aug 23, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon Pixma MP600 printer has an error coming up of 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jan 29, 2010 | Canon Pixma MP600 Printer
I have a 6A00 error code. Can you help me?
Solution 1:
Solution 2:
Solution 3:
Jan 13, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Try
Solution 1:
Solution 2:
Solution 3:
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer error code 6A00
Heello there
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6A00 on Canon Pixma Mp600
That error means the purge or cleaning station on the right where the printhead parks is jammed and can't move properly. If there is no paper stuck in there, you need a new purge assembly. about $30.00
Oct 20, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mp600 error 6A00: After you check for loose paper
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6a00 on my cannon mp600 what does it mean
simply move the cartridge back and forth a few times
Feb 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 error code U043
You will need to call our technical support line on 0845 20 20 118
Dec 24, 2008 | Canon PIXMA MP600 all-In-One InkJet...
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
3,572 people viewed this question
old marine
old marine
